I’ve recently purchases Beelink ME Pro 2 bay NAS and I wanted to share with you some of my thoughts.
I have N95 12GB version.
Interesting parts of lspci
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. Device 8126 (rev 01)
03:00.0 Ethernet controller: Intel Corporation Ethernet Controller I226-V (rev 04)
06:00.0 Network controller: MEDIATEK Corp. Device 7920
07:00.0 SATA controller: ASMedia Technology Inc. Device 1062 (rev 02)
I’m currently testing it with:
- 2 old 3TB HDD.
- 2 256GB m.2 NVMe in PCIe 3.0 x1 slot
- 1 optane M10 m.2 NVMe in PCIe 3.0 x2 slot (for more write heavy workloads)
My main point of comparison are old used HP EliteDesk 800 G3 SFF.
I’ve used them for small k8s servers and NAS.
Humble 800 G3 is 2-3 times cheaper on used market.
Similarities between NAS and 800 G3:
- 2x 3.5 HDD
- 3+ m.2 NVMe slots
Beelink ME Pro advantages over 800 G3:
- compact design
- more built in network (5GbE + 2.5GbE + wifi)
- chassis designed for HDD cooling
- cute small metal box
- modern IO, single usb-c
- Newer CPU with newer iGPU (probably better at video encode/decode)
800 G3 advantages over beelink ME Pro:
- much cheaper on used market
- real pcie slots
- up to 5 NVMe ssds in pcie slot
- 3 sata ports on the motherboard
- mount point for 2.5 drive
- only 1GbE network but can be expanded via pcie slot.
- internal power supply with standard IEC c14 socket.
- expandable RAM
These 2 devices are from different market segments, but I’m evaluating them as 2 HDD homelab nodes.
New and compact purpose built NAS vs old, bulky and not designed to cool HDDs.
On rack compatibility, ME Pro has slight disadvantage on 800 G3.
It’s too wide and you can only fit 3 of these side by side on a rack shelf.
800 G3 are much taller but you can fit 4 on one rack shelf.
HDD temperatures.
Beelink website shows fancy simulations of how airflow is supposed to work in ME Pro.
Front of the device is solid despite mesh/speaker appearance.
Air in this chassis is sucked in inside via upper HDD section. Cools the HDDs, moves to CPU area where fan pushes it through CPU heatsink and exhausts it from the case.
I was curious if it will work better than desktop PC in which cooling power hungry HDDs was an afterthought. 800 G3 CPU fan shroud help direct the air exhaust outside of the case. It may help with HDD temperatures, but it’s not impressive.
In my tests, using the same HDD model in the same room (25°C ambient) and default fan speeds on Beelink ME Pro i achieved very similar results.
As I’m writing this, both system have exactly the same temperature on their HDDs.
Both systems were online for +12h, so temperatures stabilized.
800 G3. 45°C and 42°C
Beelink ME Pro, upper HDD 42°C lower HDD 45°
it’s not impressive result, I didn’t expect it to be as bad as basic office PC.
In bios/firmware menu fan speed was reported at 1600RPM (with default fan settings)
Sadly fan speed is not reported in linux.
I may tweak fan setting in the future to bring base fan speed higher to help with HDD temperatures. But temperatures won’t get anywhere near what could be achieved in a proper nas.
Power usage.
Idling Beelink ME Pro with ubuntu server 24.04 with HWE kernel, 3 m.2 SSDs and 2 HDDs (idle HDDs but not spun down) uses 32,5W.
HDDs probably use 20W, 12W for the rest of the system isn’t that impressive. Modern office PCs have very similar if not better idle power usage.
Pcie devices run without ASPM enabled and I couldn’t find option to enable it in bios/firmware menu.
Some other oddities I’ve noticed:
- During boot Beelink ME Pro loudly beeps. Some users on reddit say it’s impossible to silence it in firmware. Only by unplugging the speaker (Haven’t tried it)
- Wifi and 5GbE chips are quite new, I needed HWE kernel on ubuntu to use them.
- Beelink ME Pro does not support HDD hot swapping. bios/firmware menu has some stat hot plug settings, but they probably refer to intel chipset sata. 2 3.5 HDDs are connected via ASMedia1062.
TL;DR
Beelink ME Pro is a really good looking small nas device.
It’s main advantages are small size (excluding power supply) and esthetics.
I really like that it has 3 m.2 slots.
Network configuration is strange and dictated by cost and pcie limitations of the CPU.
Device sacrifices upgradability to achieve this small size.
It has some strange quirks like loud beep during booting.
If you don’t care about size or aesthetics, it has no advantages over used HP 800 G3 SFF.
