bedHedd's Whipper adventure
background
As Windows 10 will be deprecated soon, I wanted to migrate my CD extraction software as well.
picking my software
On windows I currently use Exact Audio copy
I wanted to find software that would get a exact rip like EAC, so I went and read reddit.
the top replies had these results:
  • abcde
  • Asunder
  • whipper
  • cdparanoia
while researching on the web, I also came across this forum post which recommended RubyRipper
I also came across this table from hydrogen audio
During my research, I also came across this reply which linked to the music hoarders wiki
In the linux section, the wiki’s instructions used whipper.
Ultimately I decided to use whipper because I was already familiar with python, and should I need to extend/modify it, it should be easier with chatgpt.
getting started with whipper
After adding whipper to my nix config, I ran the suggested commands from the musichoarders wiki.
whipper drive analyze
/nix/store/5rwqw11kchps3kplgjzpa2law7akxskw-whipper-0.10.0/lib/python3.13/site-packages/whipper/__init__.py:5: UserWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html. The pkg_resources package is slated for removal as early as 2025-11-30. Refrain from using this package or pin to Setuptools<81.
  from pkg_resources import (get_distribution,
CRITICAL:whipper.command.drive:cannot analyze the drive: is there a CD in it?
The music hoarders wiki did not mention needing a cd in the drive before the analysis, which caused the above bug
I decided to follow the instructions from the whipper project page
“1. Pick a relatively popular CD that has a good chance of being in the AccurateRip database”
I decided to pick Weezer the blue album because it showed up here
“2. Analyze the drive’s caching behavior”
I reran the whipper drive analyze with the weezer disk in the drive
INFO:whipper.command.drive:cdparanoia can defeat the audio cache on this drive
INFO:whipper.command.drive:adding drive cache behaviour to configuration file
“3. Find the drive’s offset.”
I ran the command
whipper drive list
drive: /dev/cdrom, vendor: HL-DT-ST, model: BD-RE  WH16NS40 , release: 1.05
WARNING:whipper.command.drive:no read offset found. Run 'whipper offset find'
       Can defeat audio cache: True
then I looked for WH16NS40 on the accurip page
I have copied the table for myself. the numeric-value-here value is the offset number, which is 6
CD Drive Correction Offset Submitted By Percentage Agree
LG Electronics - BD-RE WH16NS40 +6 1199 100%
I then ran the command
whipper offset find -o 6
INFO:whipper.command.offset:checking device /dev/sr0
Track 1 finished, found 61 Q sub-channels with CRC errors
Track 2 finished, found 55 Q sub-channels with CRC errors
Track 3 finished, found 81 Q sub-channels with CRC errors
Track 4 finished, found 26 Q sub-channels with CRC errors
Track 5 finished, found 19 Q sub-channels with CRC errors
Track 6 finished, found 66 Q sub-channels with CRC errors
Track 7 finished, found 36 Q sub-channels with CRC errors
Track 8 finished, found 47 Q sub-channels with CRC errors
Track 9 finished, found 40 Q sub-channels with CRC errors
Track 10 finished, found 94 Q sub-channels with CRC errors
INFO:whipper.command.offset:trying read offset 6...
INFO:whipper.command.offset:offset of device is likely 6, confirming...
Read offset of device is: 6.
I wanted to inspect what the conf file looks like, so chatgpt suggested
echo (set -q XDG_CONFIG_HOME; and echo $XDG_CONFIG_HOME; or echo ~/.config)/whipper/whipper.conf
/home/bedhedd/.config/whipper/whipper.conf
which returned the following the path above, running cat of that file returned this.
[drive:HL-DT-ST%3ABD-RE%20%20WH16NS40%20%3A1.05]
vendor = HL-DT-ST
model = BD-RE  WH16NS40
release = 1.05
defeats_cache = True
read_offset = 6
At some point, I’ll need to add a dot file for this conf, but for now I just want to use whipper
“4. Rip the disc by running whipper cd rip”
I ran this command in a folder called whipper-test in my Music folder with a new cd in the drive
whipper cd rip
INFO:whipper.command.cd:using configured read offset 6
INFO:whipper.command.cd:checking device /dev/sr0
CDDB disc id: 790a050a
MusicBrainz disc id f3rdXVfl7uWfKZtNGB6HZgz_970-
MusicBrainz lookup URL https://musicbrainz.org/cdtoc/attach?toc=1+10+192536+150+20978+36448+53220+69898+85053+102563+127835+150657+165917&tracks=10&id=f3rdXVfl7uWfKZtNGB6HZgz_970-
Disc duration: 00:42:45.146, 10 audio tracks
Matching releases:
Artist  : 大貫妙子
Title   : Mignonne
Duration: 00:42:45.102
URL     : https://musicbrainz.org/release/16e7bdd6-fd6e-49e0-ba4c-853044bed618
Release : 16e7bdd6-fd6e-49e0-ba4c-853044bed618
Type    : Album
Barcode : 4560427464381
Country : Japan
Cat no  : MHCL-10148
Track 1 finished, found 2 Q sub-channels with CRC errors
Track 2 finished, found 4 Q sub-channels with CRC errors
Track 3 finished, found 3 Q sub-channels with CRC errors
Track 4 finished, found 4 Q sub-channels with CRC errors
Track 5 finished, found 3 Q sub-channels with CRC errors
Track 6 finished, found 4 Q sub-channels with CRC errors
Track 7 finished, found 8 Q sub-channels with CRC errors
Track 8 finished, found 4 Q sub-channels with CRC errors
Track 9 finished, found 7 Q sub-channels with CRC errors
Track 10 finished, found 7 Q sub-channels with CRC errors
INFO:whipper.program.cdrdao:creating output directory /home/bedhedd/Music/Flac/whipper-test/album/大貫妙子 - Mignonne
INFO:whipper.command.cd:ripping track 1 of 10: 01. 大貫妙子 - じゃじゃ馬娘.flac
INFO:whipper.program.cdparanoia:checksums match, e1b0502d
INFO:whipper.command.cd:CRCs match for track 1
Peak level: 1.000000
Rip quality: 100.00%
INFO:whipper.command.cd:ripping track 2 of 10: 02. 大貫妙子 - 横顔.flac
INFO:whipper.program.cdparanoia:checksums match, 214e2877
INFO:whipper.command.cd:CRCs match for track 2
INFO:whipper.command.cd:ripping track 3 of 10: 03. 大貫妙子 - 黄昏れ.flac
INFO:whipper.program.cdparanoia:checksums match, 38d4e92a
INFO:whipper.command.cd:CRCs match for track 3
Peak level: 0.999969
INFO:whipper.command.cd:ripping track 4 of 10: 04. 大貫妙子 - 空をとべたら.flac
INFO:whipper.program.cdparanoia:checksums match, 995aad25
INFO:whipper.command.cd:CRCs match for track 4
INFO:whipper.command.cd:ripping track 5 of 10: 05. 大貫妙子 - 風のオルガン.flac
INFO:whipper.program.cdparanoia:checksums match, e08dd497
INFO:whipper.command.cd:CRCs match for track 5
INFO:whipper.command.cd:ripping track 6 of 10: 06. 大貫妙子 - 言い出せなくて.flac
INFO:whipper.program.cdparanoia:checksums match, 53b0bd63
INFO:whipper.command.cd:CRCs match for track 6
Peak level: 0.963684
INFO:whipper.command.cd:ripping track 7 of 10: 07. 大貫妙子 - 4:00 A.M..flac
INFO:whipper.program.cdparanoia:checksums match, 9f21e7f3
INFO:whipper.command.cd:CRCs match for track 7
INFO:whipper.command.cd:ripping track 8 of 10: 08. 大貫妙子 - 突然の贈りもの.flac
INFO:whipper.program.cdparanoia:checksums match, 145fe3af
INFO:whipper.command.cd:CRCs match for track 8
INFO:whipper.command.cd:ripping track 9 of 10: 09. 大貫妙子 - 海と少年.flac
INFO:whipper.program.cdparanoia:checksums match, 71e23d9e
INFO:whipper.command.cd:CRCs match for track 9
INFO:whipper.command.cd:ripping track 10 of 10: 10. 大貫妙子 - あこがれ.flac
INFO:whipper.program.cdparanoia:checksums match, 1649cad1
INFO:whipper.command.cd:CRCs match for track 10
Peak level: 0.969757
INFO:whipper.image.cue:parsing .cue file 'album/大貫妙子 - Mignonne/大貫妙子 - Mignonne.cue'
INFO:whipper.common.program:1 AccurateRip response(s) found
track  1: rip accurate     (max confidence     24) v1 [3a8a0455], v2 [8a44604f], DB [8a44604f]
track  2: rip accurate     (max confidence     24) v1 [9abe895b], v2 [0d0009d1], DB [0d0009d1]
track  3: rip accurate     (max confidence     24) v1 [37b84132], v2 [5c1c9176], DB [5c1c9176]
track  4: rip accurate     (max confidence     24) v1 [c6649d64], v2 [182d2bc7], DB [182d2bc7]
track  5: rip accurate     (max confidence     24) v1 [5bde8b90], v2 [2e57ffbf], DB [2e57ffbf]
track  6: rip accurate     (max confidence     24) v1 [4143a391], v2 [8da1835c], DB [8da1835c]
track  7: rip accurate     (max confidence     24) v1 [9defa932], v2 [352b09d4], DB [352b09d4]
track  8: rip accurate     (max confidence     23) v1 [6ffd6a70], v2 [cd74a32f], DB [cd74a32f]
track  9: rip accurate     (max confidence     24) v1 [11540426], v2 [1eca9c07], DB [1eca9c07]
track 10: rip accurate     (max confidence     24) v1 [c97dd0c1], v2 [60848591], DB [60848591]
It is nice to be able to run whipper cd rip, from a directory that will dump all my music to.
May I ask why you’re not using cyanrip for this which has a tiny amount of deps and handles this just fine? :slight_smile:
One thing to note about whipper that’s really nice is that Picard can read whipper logfiles to match a CD to a database entry, or even create or link new database entries.
Not sure what you mean by this… it’s not like whipper has a huge dependency list either other then stuff for… y’know, ripping CDs.
And that aside from the research he laid out it seems fairly obvious that he didn’t run across cyanrip. Neither did I until after I already started using whipper years ago.
It’s not a huge list but certainly longer and given the fun with Python dependencies and co-existance with other Python projects I’d be careful with that :wink:
I ultimately picked whipper because if I wanted to modify it, I already understand python better than C. That said, I’m not opposed to trying it out
Yeah I didn’t see it mentioned
I decided to take a look at cyanrip since @diizzy suggested it
The readme instructions needs a getting started section because the table isn’t super clear and doesn’t give me the config to rip a high quality track
for example by default checking is disabled and doesn’t give me clear details into what to use if I want a high quality rip
-P int Sets the paranoia level to use, by default its max, 0 disables all checking completely
Furthermore, there is no instructions for how to persist offsets. As many issues as whipper has, once I set a config it will get it done. Until the documentation is updated, I plan to keep on using whipper
It’s very clear and I don’t think you read it properly?
What default checks?
All you need to set is drive offset and you’re done, you can most likely find your drive already listed:
https://www.accuraterip.com/driveoffsets.htm
https://daefeatures.co.uk/
So for a flac rip (example)… cyanrip -s 6 -d /dev/sr0
Probably, but the table takes more effort to read and understand than whipper, which gives me a step by step commands to run.
I don’t feel like writing, memorizing, or using autocomplete for the flags I need. I can configure whipper once and run whipper cd rip for any CDs in my drive. If I need to change the parameters, I’ll read through the rest.
Also while looking for any cyanrip guides online, I came across threads where you suggested it.
I would be more inclined to try it out if you wrote a guide to get started (since the repo’s readme doesn’t have it) or your own experience with cyanrip.
I’ve already already invested time into setting up whipper, so for me, cyanrip needs to have benefits/features (be either even easier to setup, faster to rip, or higher rips quality) compared to whipper.
I’m not sure what to tell you here?
Define offset, define path to drive (becuse you can have multiple) and if needed define output format and bitrate.
The -f option even does what you wrote in multiple lines in step 3.
