I'm trying to play battlefront 2 on my laptop but the game crashes every time I try to start a new game. :(
Does anyone know a fix?
What laptop do you have and what operating system? I've been able to run it easily on windows 7 at any rate. We need more information to help you.
I played this game several years ago on Windows 7 in the windows audio device manager in the recording section theres a device thats disabled or called stereo mix I enabled that and it caused the game to work. Hopefully that helps some.
I've tried the stereo mix fix(that rhymes) but it didn't work.
I solved it, I needed to plug in a monitor.
