my pc.
9900K stock turbo 4.7 . All auto settings in bios. Noctua NH-D15 .Temps 60-70C
2x16 GB DDR4 GSKILL 3000 XMP
Corsair 850RmX
Aorus 2080 Ti Xtreme , no oc,stock.
Asus Prime Z390-A newest bios
All stress tests passing fine. I dont have any crashes in game.
But 1 June i go out to work, and i left running game BF 5. When i back,game was running 14 hours,and after 14 hours it crashed/exited to desktop. Event viewer nothing . No error message,no display crash. Just exit to desktop.
I dont touch keyboard,mouse anything. Just character was standing on the same place in Campaign Singleplayer mission.
I was resting in bed on laptop when i saw this on pc. Game exited to desktop and i saw white/grey Origin with turning circle and after moment i was unable to run game again.
Here is log:
0:016> !analyze -v
- Exception Analysis *
*** WARNING: Unable to verify timestamp for dbdata.dll
KEY_VALUES_STRING: 1
Key : AV.Dereference
Value: NullClassPtr
Key : AV.Fault
Value: Read
Key : Analysis.CPU.Sec
Value: 5
Key : Analysis.Elapsed.Sec
Value: 131
Key : Analysis.Memory.CommitPeak.Mb
Value: 204
Key : Timeline.Process.Start.DeltaSec
Value: 49516
PROCESSES_ANALYSIS: 1
SERVICE_ANALYSIS: 1
STACKHASH_ANALYSIS: 1
TIMELINE_ANALYSIS: 1
Timeline: !analyze.Start
Name:
Time: 2019-06-09T17:06:57.933Z
Diff: 663944933 mSec
Timeline: Dump.Current
Name:
Time: 2019-06-02T00:41:13.0Z
Diff: 0 mSec
Timeline: Process.Start
Name:
Time: 2019-06-01T10:55:57.0Z
Diff: 49516000 mSec
DUMP_CLASS: 2
DUMP_QUALIFIER: 400
MODLIST_WITH_TSCHKSUM_HASH: ecae460c3b09697da4b7d808edddb7af9cabb419
MODLIST_SHA1_HASH: b436539aa6f3750791d04ac1da7f12b3daf8b6e7
COMMENT: Frostbite MiniDump. Address: 0000000145DE184D (In Windbg type: .ecxr)
[EOF]
NTGLOBALFLAG: 0
PROCESS_BAM_CURRENT_THROTTLED: 0
PROCESS_BAM_PREVIOUS_THROTTLED: 0
DUMP_FLAGS: a2
DUMP_TYPE: 11
CONTEXT: (.ecxr)
rax=00000000abd23ce0 rbx=00000000accc5820 rcx=0000000000000000
rdx=0000000000000000 rsi=000000000055fd80 rdi=0000000033fe2710
rip=0000000145de184d rsp=0000000033fe1a00 rbp=0000000033fe1be0
r8=0000000000000006 r9=0000000000000001 r10=0000000000000006
r11=0000000033fe1a68 r12=0000000000000000 r13=0000000000000000
r14=ffffffffffffffff r15=0000000000000000
iopl=0 nv up ei pl zr na po nc
cs=0033 ss=002b ds=002b es=002b fs=0053 gs=002b efl=00010246
bfv+0x5de184d:
0000000145de184d 488b5238 mov rdx,qword ptr [rdx+38h] ds:00000000
00000038=???
Resetting default scope
FAULTING_IP:
bfv+5de184d
00000001`45de184d 488b5238 mov rdx,qword ptr [rdx+38h]
EXCEPTION_RECORD: (.exr -1)
ExceptionAddress: 0000000145de184d (bfv+0x0000000005de184d)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: 0000000000000038
Attempt to read from address 0000000000000038
DEFAULT_BUCKET_ID: NULL_CLASS_PTR_READ
PROCESS_NAME: bfv.exe
FOLLOWUP_IP:
bfv+5de184d
READ_ADDRESS: 0000000000000038
ERROR_CODE: (NTSTATUS) 0xc0000005 -
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 -
EXCEPTION_CODE_STR: c0000005
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: 0000000000000038
WATSON_BKT_PROCSTAMP: 5047ff9c
WATSON_BKT_MODULE: bfv.exe
WATSON_BKT_MODSTAMP: 5cdbc3d7
WATSON_BKT_MODOFFSET: 5de184d
WATSON_BKT_MODVER: 1.0.72.44435
BUILD_VERSION_STRING: 17763.1.amd64fre.rs5_release.180914-1434
ANALYSIS_SESSION_HOST: DESKTOP-RVP2EUM
ANALYSIS_SESSION_TIME: 06-09-2019 19:06:57.0933
ANALYSIS_VERSION: 10.0.18869.1002 amd64fre
THREAD_ATTRIBUTES:
OS_LOCALE: PLK
BUGCHECK_STR: APPLICATION_FAULT_NULL_CLASS_PTR_READ_NULL_CLASS_PTR_DEREFERENCE_INVALID_POINTER_READ
PRIMARY_PROBLEM_CLASS: APPLICATION_FAULT
PROBLEM_CLASSES:
Type: [@ACCESS_VIOLATION]
Class: Addendum
Scope: BUCKET_ID
Data: Omit
PID: [Unspecified]
TID: [0xb30]
Frame: [0] : bfv
Type: [INVALID_POINTER_READ]
Class: Primary
Scope: BUCKET_ID
Data: Omit
PID: [Unspecified]
TID: [0xb30]
Frame: [0] : bfv
Type: [NULL_CLASS_PTR_DEREFERENCE]
Class: Primary
Scope: BUCKET_ID
Data: Omit
PID: [Unspecified]
TID: [0xb30]
Frame: [0] : bfv
Type: [NULL_CLASS_PTR_READ]
Class: Primary
Scope: DEFAULT_BUCKET_ID (Failure Bucket ID prefix)
BUCKET_ID
Data: Omit
PID: [0x28cc]
TID: [0xb30]
Frame: [0] : bfv
IP_ON_HEAP: 0000000000400000
The fault address in not in any loaded module, please check your build’s rebase
log at \bin\build_logs\timebuild\ntrebase.log for module which may
contain the address if it were loaded.
FRAME_ONE_INVALID: 1
LAST_CONTROL_TRANSFER: from 0000000000400000 to 0000000145de184d
STACK_TEXT:
0000000033fe1a00 00000000
00400000 : 00000002145b8ca0 00000000
0055fd80 00000002188990d0 00000000
00000000 : bfv+0x5de184d
0000000033fe1a08 00000002
145b8ca0 : 000000000055fd80 00000002
188990d0 0000000000000000 00000000
00000000 : 0x400000
0000000033fe1a10 00000000
0055fd80 : 00000002188990d0 00000000
00000000 0000000000000000 00000000
33fe2710 : 0x00000002145b8ca0 00000000
33fe1a18 00000002188990d0 : 00000000
33fe2710 0000000145e11736 : 0x55fd80 00000000
33fe1a20 0000000000000000 : 00000000
00000000 0000000033fe2710 00000001
45e11736 0000000000000006 : 0x00000002
188990d0
THREAD_SHA1_HASH_MOD_FUNC: f86e706f3881ff99410f64522468510881cb97a0
THREAD_SHA1_HASH_MOD_FUNC_OFFSET: fc53bee7bd5eee7c273e1f674a644f5504b35eba
THREAD_SHA1_HASH_MOD: f86e706f3881ff99410f64522468510881cb97a0
FAULT_INSTR_CODE: 38528b48
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: bfv+5de184d
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: bfv
IMAGE_NAME: bfv.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 5cdbc3d7
STACK_COMMAND: ~16s ; .ecxr ; kb
FAILURE_BUCKET_ID: NULL_CLASS_PTR_READ_c0000005_bfv.exe!Unknown
BUCKET_ID: APPLICATION_FAULT_NULL_CLASS_PTR_READ_NULL_CLASS_PTR_DEREFERENCE_INVALID_POINTER_READ_bfv+5de184d
FAILURE_EXCEPTION_CODE: c0000005
FAILURE_IMAGE_NAME: bfv.exe
BUCKET_ID_IMAGE_STR: bfv.exe
FAILURE_MODULE_NAME: bfv
BUCKET_ID_MODULE_STR: bfv
FAILURE_FUNCTION_NAME: Unknown
BUCKET_ID_FUNCTION_STR: Unknown
BUCKET_ID_OFFSET: 5de184d
BUCKET_ID_MODTIMEDATESTAMP: 5cdbc3d7
BUCKET_ID_MODCHECKSUM: ef4e508
BUCKET_ID_MODVER_STR: 1.0.72.44435
BUCKET_ID_PREFIX_STR: APPLICATION_FAULT_NULL_CLASS_PTR_READ_NULL_CLASS_PTR_DEREFERENCE_INVALID_POINTER_READ_
FAILURE_PROBLEM_CLASS: APPLICATION_FAULT
FAILURE_SYMBOL_NAME: bfv.exe!Unknown
TARGET_TIME: 2019-06-02T00:41:13.000Z
OSBUILD: 17763
OSSERVICEPACK: 475
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK: 256
PRODUCT_TYPE: 1
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
OSEDITION: Windows 10 WinNt SingleUserTS
USER_LCID: 0
OSBUILD_TIMESTAMP: 1989-09-10 08:58:46
BUILDDATESTAMP_STR: 180914-1434
BUILDLAB_STR: rs5_release
BUILDOSVER_STR: 10.0.17763.1.amd64fre.rs5_release.180914-1434
ANALYSIS_SESSION_ELAPSED_TIME: 2033c
ANALYSIS_SOURCE: UM
FAILURE_ID_HASH_STRING: um:null_class_ptr_read_c0000005_bfv.exe!unknown
FAILURE_ID_HASH: {f476daa4-68b6-2895-45dc-838c7fe6b3de}
Followup: MachineOwner
0:016> !analyze -v
Value: NullClassPtr
Key : AV.Fault
Value: Read
Value: 1
Value: 1
Value: 211
Value: 49516
SERVICE_ANALYSIS: 1
Name:
Time: 2019-06-09T17:09:09.843Z
Diff: 664076843 mSec
Name:
Diff: 0 mSec
Name:
Diff: 49516000 mSec
DUMP_CLASS: 2
DUMP_QUALIFIER: 400
[EOF]
NTGLOBALFLAG: 0
DUMP_FLAGS: a2
DUMP_TYPE: 11
CONTEXT: (.ecxr)
bfv+0x5de184d:
00000038=???
FAULTING_IP:
bfv+5de184d
NumberParameters: 2
FOLLOWUP_IP:
bfv+5de184d
ANALYSIS_SESSION_TIME: 06-09-2019 19:09:09.0843
THREAD_ATTRIBUTES:
OS_LOCALE: PLK
PROBLEM_CLASSES:
Class: Addendum
Scope: BUCKET_ID
Data: Omit
PID: [Unspecified]
TID: [0xb30]
Frame: [0] : bfv
Class: Primary
Scope: BUCKET_ID
Data: Omit
PID: [Unspecified]
TID: [0xb30]
Frame: [0] : bfv
Class: Primary
Scope: BUCKET_ID
Data: Omit
PID: [Unspecified]
TID: [0xb30]
Frame: [0] : bfv
Class: Primary
BUCKET_ID
Data: Omit
PID: [0x28cc]
TID: [0xb30]
Frame: [0] : bfv
STACK_TEXT:
00000000 : 0x400000
188990d0
MODULE_NAME: bfv
IMAGE_NAME: bfv.exe
OSBUILD: 17763
OSSERVICEPACK: 475
OS_REVISION: 0
SUITE_MASK: 256
PRODUCT_TYPE: 1
OSNAME: Windows 10
USER_LCID: 0
ANALYSIS_SESSION_ELAPSED_TIME: 76d
ANALYSIS_SOURCE: UM
0:016> !analyze -v
Value: NullClassPtr
Key : AV.Fault
Value: Read
Value: 1
Value: 1
Value: 219
Value: 49516
SERVICE_ANALYSIS: 1
Name:
Time: 2019-06-09T17:09:11.746Z
Diff: 664078746 mSec
Name:
Diff: 0 mSec
Name:
Diff: 49516000 mSec
DUMP_CLASS: 2
DUMP_QUALIFIER: 400
[EOF]
NTGLOBALFLAG: 0
DUMP_FLAGS: a2
DUMP_TYPE: 11
CONTEXT: (.ecxr)
bfv+0x5de184d:
00000038=???
FAULTING_IP:
bfv+5de184d
NumberParameters: 2
FOLLOWUP_IP:
bfv+5de184d
ANALYSIS_SESSION_TIME: 06-09-2019 19:09:11.0746
THREAD_ATTRIBUTES:
OS_LOCALE: PLK
PROBLEM_CLASSES:
Class: Addendum
Scope: BUCKET_ID
Data: Omit
PID: [Unspecified]
TID: [0xb30]
Frame: [0] : bfv
Class: Primary
Scope: BUCKET_ID
Data: Omit
PID: [Unspecified]
TID: [0xb30]
Frame: [0] : bfv
Class: Primary
Scope: BUCKET_ID
Data: Omit
PID: [Unspecified]
TID: [0xb30]
Frame: [0] : bfv
Class: Primary
BUCKET_ID
Data: Omit
PID: [0x28cc]
TID: [0xb30]
Frame: [0] : bfv
STACK_TEXT:
00000000 : 0x400000
188990d0
MODULE_NAME: bfv
IMAGE_NAME: bfv.exe
OSBUILD: 17763
OSSERVICEPACK: 475
OS_REVISION: 0
SUITE_MASK: 256
PRODUCT_TYPE: 1
OSNAME: Windows 10
USER_LCID: 0
ANALYSIS_SOURCE: UM
I tried to reproduce this but i cant. I left game running 3xtimes for 20 hours and nothing again,game is runnin.
