I plan to build some Threadripper Linux workstations for software development. We just need some basic GPUs (no GPU programming, just for basic display purposes). We need to support two monitors, probably 1440p. I’ve love something which doesn’t require proprietary drivers for simplicity.
I’d suggest some Radeon RX550 variant that has proper display outputs. Cheapest one here in Finland is ASRock Phantom Gaming Radeon RX550 (125,00€) and it has DisplayPort 1.4 and HDMI 2.0. Those two connections actually supports even 4K resolution.
I purchased one for my church’s live stream build. Works very well for light weight purposes, and the OS drivers work well with my 480 so I assume they would work well here too.
I would suggest getting a rx 550 2G, you will probably find older gen cards for cheaper, but for the longest/best driver support, the rx 550 is better because it’s still pretty new.
Kernel driver support for newer amd cards is excellent, so whatever you do, don’t go with nvidia.
Also, make sure you get a card with a zero rpm mode, if the card has it, the OEM will usually advertize it. Some cheap coolers without a zero rpm mode can be annoyingly loud even when idle.
Maybe it makes sense to step up a bit? The main question I think is how much of a difference will it make for Linux desktop (Gnome 3 I’d assume). Does the RX580 have better mainline Linux kernel support? Do any of these cards face the same problems that I face with the integrated “vega” graphics?
I figured I’d ask these questions so someone with these cards will see it and answer it for us.
I don’t have a 550 but I have a 460 in use and it is supported perfectly, same as 470/480/570/580, polaris based Radeon Pro and all standalone Vega cards.
No. I have a bunch of polaris cards running and Vega64 in my gaming rig. None of those machines show any sign of that behavior.
After my last adventure with Asus, I don’t trust them to not screw up a BIOS update on notebooks. I am sure Asus desktop motherboards are fine because BIOS flashback (A/B thing) but not so sure about notebooks.
I am still hoping for a fix without updating the BIOS…
