I’m attempting to write an service install and configuration script for my servers. This is the script in it’s nearly finished state. I’m currently ironing out my confusion regarding apache configs and WSGI services through apache (thread expected to arrive in a few days unless I solve it before then).
I hope to receive some criticism on it and I also hope for it to be of use for somebody else wishing to run similar setups.
#! /bin/bash
#Give instructions
echo "This script needs you to have port forwarding and DNS set up correctly for the ssl generation to function.
If this isn't done press ctrl+c to cancel execution
sleep 2
# todo:
# Setup ssl for nextcloud
# Generate directory system explanation in file /srv/help (I keep forgetting!)
# Check that mysql uses socket
# Correct permissions for /srv/onion1 so tor starts
# Add passwords to deluge correctly
echo "Installing relevant software"
echo "
deb http://ftp.debian.org/debian jessie-backports main
" >> /etc/apt/sources.list
read -s -p "Enter mysql root password and make note of it securely
(it won't be visible as you write)
" DBPASSWD
read -s -p "Enter nextcloud admin password and make note of it securely
" NEXTCLOUD_PASSWD
read -s -p "Enter deluge login password and make note of it securely
" DELUGE_PASSWORD
apt-get -q update
echo "mysql-server mysql-server/root_password select $DBPASSWD" | debconf-set-selections
echo "mysql-server mysql-server/root_password_again select $DBPASSWD" | debconf-set-selections
apt-get -y -q install tor sudo openssh-server samba deluged deluge-web apache2-utils apache2 php php-mysql php-gd php-curl php-zip php-dom php-xml php-mbstring mysql-server
#apt-get -y -q install python-certbot-apache -t jessie-backports
echo "Adding users and groups"
echo "Set password and other information for local user sid"
adduser sid
addgroup torrent
adduser sid torrent
adduser debian-deluged torrent
addgroup onion
adduser sid onion
addgroup stor
adduser sid stor
echo "Configuring directories and permissions"
#Making directories
mkdir /srv/onion1
mkdir /srv/onion2
mkdir /srv/stor
mkdir /srv/old
mkdir /srv/torrent
mkdir /srv/torrent/torrent-files
mkdir /srv/torrent/downloads
mkdir /srv/public
mkdir /srv/www
mkdir /srv/db
#Linking /home in case of storing home on hdd
ln -s /home /srv/home
#Setting permissions
chmod -R 0750 /srv
chmod 0775 /srv
chmod -R 0775 /srv/stor
chmod -R 0755 /srv/old
chmod -R 0775 /srv/public
chmod 0775 /srv/www
chmod 0640 /srv/onion1
chmod 0640 /srv/onion2
chown -R sid:sid /srv
chown -R sid:torrent /srv/torrent
chown -R sid:stor /srv/stor
chown -R debian-tor:onion /srv/onion1
chown -R debian-tor:onion /srv/onion2
chown -R www-data:www-data /srv/public
chown -R www-data:www-data /srv/www
#add user sid to samba
echo "set password for samba user sid"
smbpasswd -a sid
echo "Configuring ssh and sftp for connection over tor, web and LAN"
echo "
#Allow connections to these adresses
Host *.onion *sidju* 10.* 192.168.* localhost 127.0.0.1
#Global settings
Match originalhost *
#compress data to minimize bandwidth use
Compression yes
#Limit password retries
NumberOfPasswordPrompts 2
#Passwords are allowed. Use identity keys only for improved security
PasswordAuthentication yes
#root login is disabled by default
" > /etc/ssh/ssh_config
invoke-rc.d sshd restart
echo "Configuring hidden service hosting in /srv/onion1"
cp /etc/tor/torrc /etc/tor/torrc.old
echo "
User debian-tor
#Configure hidden services
HiddenServiceDir /srv/onion1
HiddenServicePort 80 127.0.0.1:80
HiddenServicePort 83 127.0.0.1:83
HiddenServicePort 8112 127.0.0.1:8112
HiddenServicePort 22 127.0.0.1:22
#Require password to connect to service
HiddenServiceAuthorizeClient stealth sid,sidserv,other
" > /etc/tor/torrc
#Restart tor when directory permissions are correct for the configuration to work
invoke-rc.d tor restart
echo "Configuring samba sharing of /srv/stor, /srv + / (for administration) and home directories"
#set error file when smb crasches
echo "#! /bin/bash
touch /home/sid/SambaHasCrasched!!!!" > /etc/samba_crasch_action.sh
echo "[global]
workgroup = SIDNET
security = user
map to guest = bad user
guest account = nobody
#Store passwords encrypted
encrypt passwords = yes
server role = standalone server
#setup logging
log file = /var/log/samba/log.%m
max log size = 100
syslog = 0
#set crash warning in visible location
panic action = /etc/samba_crash_action.sh
#Setup user backend
passdb backend = tdbsam
#Set root permissions for root (uneccesary?)
admin users = root
#Disable irrelevant accounts
invalid users = daemon bin sys sync games man lp mail news uucp proxy www-data backup list irc gnats systemd-timesync systemd-network systemd-resolve systemd-bus-proxy Debian-exim messagebus statd debian-deluged sshd debian-tor
#Limit connections
deadtime = 60
max connections = 20
#Share the connected user's home directory
[homes]
read only = no
browseable = no
create mask = 0700
directory mask = 0700
follow symlinks = no
invalid users = nobody
#share /srv/stor for general access
[stor]
path = /srv/stor
read only = yes
create mask = 0755
directory mask = 0755
guest ok = yes
#share /srv for administration
[srv]
path = /srv
read only = no
valid users = root sid
administrative share = yes
#share / for administration
[root]
path = /
read only = no
valid users = root
follow symlinks = yes
" > /etc/samba/smb.conf
invoke-rc.d smbd restart
invoke-rc.d nmbd restart
echo "Configuring deluge"
mkdir /var/log/deluge
rmdir /var/log/deluged
chown -R debian-deluged /var/lib/deluged
chown -R debian-deluged /var/log/deluge
#Autostart daemon
echo "[Unit]
Description=Deluge Bittorrent Client Daemon
After=network-online.target
[Service]
Type=simple
User=debian-deluged
Group=torrent
UMask=007
ExecStart=/usr/bin/deluged -d -l /var/log/deluge/daemon.log -L info
Restart=on-failure
# Configures the time to wait before service is stopped forcefully.
TimeoutStopSec=300
[Install]
WantedBy=multi-user.target
" > /etc/systemd/system/deluged.service
systemctl enable /etc/systemd/system/deluged.service
systemctl start deluged
#Autostart web ui
echo "[Unit]
Description=Deluge Bittorrent Client Web Interface
[Service]
Type=simple
User=debian-deluged
Group=torrent
UMask=027
ExecStart=/usr/bin/deluge-web -l /var/log/deluge/web-ui.log -L info
Restart=on-failure
[Install]
" > /etc/systemd/system/deluge-web.service
systemctl enable /etc/systemd/system/deluge-web.service
systemctl start deluge-web
echo "Waiting for deluge"
echo "4"
sleep 2
echo "3"
sleep 2
echo "2"
sleep 2
echo "1"
sleep 2
echo "0"
systemctl stop deluge-web
systemctl stop deluged
#Write config file for deluge
cp ./core.conf /var/lib/deluged/.config/deluge/core.conf
#Add authentications
echo "sid:$DELUGE_PASSWORD:10" >> /var/lib/deluged/.config/deluge/auth
#last permissions check
#Setup apache2
#Automate cleaning of the shared dir (only symlinks allowed)
#todo: chron job for this (and backups)
echo "#! /bin/bash
find /srv/public -type f -delete"
#Backup default config file (useful information)
cp /etc/apache2/apache2.conf /etc/apache2/apache2.conf.old
#Write new config file
echo "ServerRoot \"/etc/apache2\"
Mutex file:\${APACHE_LOCK_DIR} default
PidFile \${APACHE_PID_FILE}
#Configure general behavior
Timeout 512
KeepAlive On
MaxKeepAliveRequests 32
KeepAliveTimeout 16
#Set process owner and rights
User \${APACHE_RUN_USER}
Group \${APACHE_RUN_GROUP}
#Configure logging
HostnameLookups Off
ErrorLog \${APACHE_LOG_DIR}/error.log
LogLevel warn
#Custom log formats (for use with CustomLog setting)
LogFormat \"%v:%p %h %l %u %t \\\"%r\\\" %>s %O \\\"%{Referer}i\\\" \\\"%{User-Agent}i\\\"\" vhost_combined
LogFormat \"%h %l %u %t \\\"%r\\\" %>s %O \\\"%{Referer}i\\\" \\\"%{User-Agent}i\\\"\" combined
LogFormat \"%h %l %u %t \\\"%r\\\" %>s %O\" common
LogFormat \"%{Referer}i -> %U\" referer
LogFormat \"%{User-agent}i\" agent
#Configure automatic adding of settings from directories
IncludeOptional mods-enabled/*.load
IncludeOptional mods-enabled/*.conf
#ports to listen on read from ports.conf file (unused)
#Include ports.conf
#Forbid web access to all directories by default
<Directory />
AllowOverride None
Require all denied
</Directory>
#read access controlling files and prevent
#them from being viewed from the web
AccessFileName .htaccess
<FilesMatch \"^\.ht\">
Require all denied
</FilesMatch>
#Read config from sites-enabled and conf-enabled
IncludeOptional sites-enabled/*.conf
IncludeOptional conf-enabled/*.conf
" > /etc/apache2/apache2.conf
#Configure sharing of the public directory
echo "#Set the directory to be shared behind port 83 (ascii "S")
Listen 83
<VirtualHost *:83>
ServerName sidju.tech
DocumentRoot /srv/public
</VirtualHost>
#Set correct sharing for directory
<Directory /srv/public>
Options Indexes FollowSymLinks
AllowOverride None
Require all granted
</Directory>
" > /etc/apache2/sites-available/html_83.conf
touch /etc/apache2/mime.types
#Preparing nextcloud installation
echo "Downloading nextcloud installation files"
wget https://download.nextcloud.com/server/releases/nextcloud-12.0.0.tar.bz2 -P /srv/www/
echo "Extracting....."
tar -xjf /srv/www/nextcloud-*.tar.bz2 -C /srv/www/
rm -f /srv/www/nextcloud-*
chown -R www-data:www-data /srv/www/nextcloud/
cd /srv/www/nextcloud/
#Check function of this next part
#Setup mysql database and user for owncloud
systemctl stop mariadb
#Move mysql/mariadb directory
rsync -av /var/lib/mysql/ /srv/db/
rsync -av /var/lib/mysql/ /var/lib/mysql.old/
mount --bind /srv/db /var/lib/mysql
echo "/srv/db /var/lib/mysql none defaults,bind 0 0" >> /etc/fstab
echo "
#Secure server side config
[mysqld]
#The datadir is stored in /srv/www/db/
datadir=/srv/www/db
#Run through socket without networking
socket=/var/run/mysqld/mysqld.sock
skip-networking
[mysql]
protocol=SOCKET
" > /etc/mysql/my.cnf
chmod 0600 /etc/mysql/my.cnf
#Configure php-mysql to connect to the right socket (no need?)
echo "reenabling mysqld with new config"
#Start mysqld again
systemctl enable mariadb
systemctl start mariadb
#Harden security
mysql --user=root --password=$DBPASSWD -e "DELETE FROM mysql.user WHERE User='';"
mysql --user=root --password=$DBPASSWD -e "DELETE FROM mysql.user WHERE User='root' AND Host NOT IN ('localhost', '127.0.0.1', '::1');"
mysql --user=root --password=$DBPASSWD -e "DROP DATABASE test;"
mysql --user=root --password=$DBPASSWD -e "DELETE FROM mysql.db WHERE Db='test' OR Db='test\\_%';"
#Add database nextcloud and user nextcloud as admin of it
# create random password
NEXTCLOUD_DB_PASSWD="$(openssl rand -base64 12)"
MAINDB="nextcloud"
mysql --user=root --password=$DBPASSWD -e "CREATE DATABASE ${MAINDB} /*\!40100 DEFAULT CHARACTER SET utf8 */;"
mysql --user=root --password=$DBPASSWD -e "CREATE USER ${MAINDB}@localhost IDENTIFIED BY '${NEXTCLOUD_DB_PASSWD}';"
mysql --user=root --password=$DBPASSWD -e "GRANT ALL PRIVILEGES ON ${MAINDB}.* TO '${MAINDB}'@'localhost';"
mysql --user=root --password=$DBPASSWD -e "FLUSH PRIVILEGES;"
echo $NEXTCLOUD_DB_PASSWD >> tmp_pass.txt
echo $NEXTCLOUD_PASSWD >> tmp_pass2.txt
#test occ command outside of script first
sudo -u www-data php occ maintenance:install --database "mysql" --database-name "nextcloud" --database-user "nextcloud" --database-pass "$(cat tmp_pass.txt)" --admin-user "sid" --admin-pass "$(cat tmp_pass2.txt)"
cd /mnt
#Set port 80 and 443 to owncloud
echo "#Share nextcloud behind port 80
Listen 80
<VirtualHost *:80>
DocumentRoot /srv/www/nextcloud
</VirtualHost>
#Use alias if other service in web-root
Alias /nextcloud "/var/www/nextcloud/"
<Directory /srv/www>
Options +FollowSymlinks
AllowOverride All
Require all granted
<IfModule mod_dav.c>
Dav off
</IfModule>
SetEnv HOME /srv/www/nextcloud
SetEnv HTTP_HOME /srv/www/nextcloud
</Directory>" > /etc/apache2/sites-available/nextcloud_80.conf
echo "testing certbot to generate config for port 443"
#certbot --apache
echo "#Share nextcloud behind port 443
<IfModule mod_ssl.c>
Listen 443
<VirtualHost *:443>
ServerAdmin [email protected]
SSLEngine on
SSLCertificateFile /srv/www/ssl/sidju.tech.pem
SSLCertificateKeyFile /src/www/ssl/sidju.tech.key
" > /tmp/tmp.conf # /etc/apache2/sites-available/nextcloud_443.conf
#Configure what services are enabled
a2dissite 000-default.conf
a2ensite html_83.conf
a2ensite nextcloud_80.conf
#Enable some mods for nextcloud's sake
a2enmod rewrite
a2enmod headers
a2enmod env
a2enmod dir
a2enmod mime
systemctl enable apache2
systemctl stop apache2
systemctl start apache2
#Instruct the users
#Write help file to /srv/help.txt
echo "
Before nextcloud can be used you must run the configuration wizard available on port 80 of this server.
In the top of the page you enter username and password for the admin user.
In the bottom enter database user \"root\" and the database password you chose before. Preferably you'll name the database nextcloud...
To access the different services users need to be members of the groups
onion (read .onion urls and passphrases in /srv/onion*),
torrent (rw permission in otherwise locked /srv/torrents) and
stor (rw instead of ro in /srv/stor).
For samba access users also need to be added through \"smbpasswd -a [username]\"
This has been written to the file /srv/help.txt" > /srv/help.txt
#add space for readability
echo "
#Print help file on screen
cat /srv/help.txt
Ps. I’m aware that there is a password in this script. It is a placeholder which will be replaced with another password prompt later, when testing is done and the script finalized.
EDIT: Updated on april 6:th
EDIT 2: I have foregone this in favour of freenas. Latest version is here for whomever might wish to use it.
