Been a few months. Small status update.
Already has jumped by +$600 at my local hardware shop. Glad I pulled the trigger.
Re: AI
I still don’t use any IDE integration or agents. I copy paste code back and forth into Open WebUI to solve specific problems. Maybe I’m still too hesitant old man brain that doesn’t want too much deep integration yet. And I certainly won’t have agents touching my system settings or having the ability to install packages.
But man these local LLMS are objectively very useful and getting pretty decent. Dropping in classes or functions and asking it questions. Giving it stack traces. Pretty neat tool.
Often I don’t like the format of answers. I’ll reformat the code into my style and standards, remove unnecessary comments. And I hate the useless unnecessary emojis that a lot of models like to inject into answers (and sometimes even code) for absolutely no reason. Thankfully this is easily solved via a global system prompt Don't use emoji's in explanations or code.
I like to program without AI sometimes and only fall back to it for certain questions or problems. I have been programming for a long time before LLMs and I do not wish to deskill, so I try to keep sharp and exercise without overreliance on it. Even if the AI can be faster than me for certain things, I still want to use my brain.
It is also useful for many non-programming tasks too, such as general system maintenance. For example just recently I had an ssh session disconnect while doing an apt-get upgrade on another system, and it must have stopped at a prompt or something because when I reconnected I couldn’t update as the old process was lingering in limbo or something:
Waiting for cache lock: Could not get lock /var/lib/dpkg/lock-frontend. It is held by process 26785 (apt)
Told my GPU about my updating woes, provided the error and it told me the solution; first to kill that process then --configure:
sudo kill -9 26785
sudo dpkg --configure -a
And afterwords I can update again! All without having to touch the internet.
I have many other such trouble shooting examples solved locally. Life is good.
Re: Games
Don’t think I’ll bother with the hassle of water cooling. Again the noise doesn’t really bother me too much as I mostly game with headphones. It’s “good enough” IMO, but certainly far from silent.
Pretty much every game running flawlessly with the R9700.
Recently picked up Body Cam, and its a lot of fun. Bit of a twist on the classic FPS perspective.
The only game that has given issues so far is Battlefield 4 via Lutris. It’s an older title, but still holds up and modern BF titles wont run on Linux due to their garbage AC solutions…
Unfortunately with the R9700 there is some sort of rendering artifacting where parts of the map or certain layers are flickering in and out of existence. Tried tweaking all sorts of in-game graphics settings to no success. The flickering is bad enough to the point where it is unplayable. Wasn’t an issue on the 6750.
Nothing in the logs. Unsure how to diagnose that further. Perhaps I’ll have to have a session where I sit down and interrogate my GPU why it is unable to render that game…
Overall very happy with the upgrade.
The 6750 has sat on my desk unused since swapping. Might sell, might hold onto just in case, idk.
I’ve heard rumors of a 64GB RXXXX variation, which might be tempting if the prices aren’t too insane at that point. Probably better to have it all on the one GPU than deal with multi-GPU hoops and hassle.
Also very curios about something like the Huawei Atlas 300I Duo. Probably much worse for gaming but 96GB for AI would probably be pretty sweet.
