ive just found this out with the latest beta of vivaldi and its amazing
you can put to tabs side by side vertically or horizontal or if you have enough a cube if you have a big enough screen for it to work well
Love vivaldi
same its my favourte browser by far the only reason i dont use it all the time is its in beta so it glitches out sometimes
Yeah, love it, didn't realise this feature was available, how do you use it?
I hope when the full program is released to use it as my "daily driver"
I am on Vivaldi now. I just needed to get AdBlock Plus and Its already better than chrome.
That is impressive. Tiling in a browser. I finally might make the switch from Chrome.
Though I think this feature has been in Vivaldi for a while, since I'm using version 303.52 and I have it while Vivaldi is offering me 344.37 update. (updated though while typing)
Only have a 1920x1080 monitor so I'll probably utilize only two tabs side by side.
Maybe two tabs vertically + third on the side when I'm in a pickle.
Anything else like three side by side or four in a cube doesn't really work that well with this kind of resolution to play with.
Seriously need a new monitor..
yeah im running the same res and im doing 2X2 its not bad it depends on what type of websites you have open at the moment i have multiple tabs for the forum :D which is very handy
