I have been compressing my media since 2017. First starting with x265/h265. In 2021 I began with AV1. The gist is AV1 provides better compression and efficiency. Basically allowing for better video quality at the same given size as to h265. Having similar quality while shrinking storage is helpful for me as well as others trying to reduce bandwidth with streaming over the internet. It also shrinks used disk space.
I have traditionally used handbrake prior to my usage of av1. AV1 in the past been extremely slow going without tools such as av1an and vapoursynth. Av1an splits a video file into chucks and thus makes the traditional single threaded task of encoding av1 a multi threaded task. For most people doing this, you would want to compile the binaries from source. Setting the march to native and thus squeezing out every bit of performance you could. Even with thread utilization at 100%, av1 encoding still was not ideal for most people. My 5950x saw 7fps on a slow to medium preset where as h.265 on medium saw 50+ fps.
I have been encoding using av1an since 2021.
Ideally, it will improve as progress is made with development.
Anyways. With libaom (aomenc) and libopus (audio encoder) I would see huge gains on compression while not seeing too much loss. But with everything there will be loss in quality. I would shrink with a crf setting between 16-23 (depending on my content) and preset of 3 (smaller number means better compression but slower at doing so). A newer bluray file such as Doom Patrol (2019) would have a end result with crf of 16 and preset 3 of less than 1.2GB/episode. The source file for compression was between 7 and 10GB.
I recently moved to Intelâs software encoder (svt-av1). It utilizes threads much better and has similar end results compared to libaom.
With all this said is it worth it? For most people it is not. Most streaming devices still do not support av1 and h.265 is much easier to use for the simple fact that it is and has been wildly adopted. h.266 is still being actively developed. However, if you want bleeding edge and to support foss and royalty free codecs. AV1 and OPUS are your ideal candidates.
I will post my below steps for setting up a computer with av1. As well as my script for actual batch file compression.
