Hi,
I’m running Tahoe beta 6, and can’t for the life of me configure automount of SMB shares from Truenas server.
Method from previous versions with auto_master, auto_smb doesn’t work.
Did anyone succeed in automounting SMB shares on Tahoe?
Update…
I found an app that could have solved the problem, but it has a showstopper bug.
App is called “Network Share Mounter” developed by FAUmac Team @ FAU.
Bug is that when you add a smb share with username and password app defaults to kerberos auth and on reboot fails to mount shares. Also, you can’t change the default authentification method in preferences.
If someone (developers perhaps?) have an idea it would be awsome!
It’s hard to tell, without more info, but I would guess it’s a macOS problem.
I have several sites that use TrueNAS as a file server. Windows and Linux have little or no problems with smb or nfs shares, just Apple is problematic.
