Sorry guys this is my 3rd post. But i've finally come down to it and i need help with the MoBo
http://au.pcpartpicker.com/user/Yooittee/saved/2QNT
This is the build i finally have come to (yet again) and i'd like to know if the motherboard is fine with this build and if this is just a all round solid build and can work with WoW and LoL on max settings and be able to watch 1080p streams. This is my budget it comes to a total of $1061 including fans,cables, WiFi, postage and surcharges.
I can upgrade later on , but i'd like to know if this is capable of actually working smoothly without frying etc.
I really want to just get a solid build i'm happy with but everyone keeps changing my mind and hurting my wallet. This is stressing me out and i'd love if you a few guys can just give me positive feedback so i can get this over and done with!
Would really appreciate it. thank you guys
AU prices are so high, and the selection is so limited :/
It will probably work, but the motherboard might throttle your CPU due to the VRMs not being capable of handling the power hungry 8 core CPUs(VRM Throttling).
I tried to stay with your budget, but the only way I can do so without downgrading components would be removing the ODD :P. The motherboard I picked has a digital 6+2 power phase design(versus 4+1 on the asrock) and can handle the FX-8320 quite well. The HD 7950 is equivalent to the 760/670.
http://au.pcpartpicker.com/p/242qe
And I've wired non-modular PSUs in M-ITX cases. They're not that bad.
http://www.pccasegear.com/sc/kU8
thats with substituting some of your ideas. that will cost me $1102. With postage, surcharges and GST
Also i'm getting WiFi and fans and a few extra cables. I cannot put in the RAM you suggested because it's not on this site that i'm buying everything from otherwise i'll have to pay double postage. If you can find me a RAM suitable on this site 95-105$ i will throw that in. Thanks
The ram you picked will work. If you don't care about looks, the cheaper RAM kits with no heatsink will work just fine.
HD 7950: http://www.pccasegear.com/index.php?main_page=product_info&cPath=193_1311&products_id=25636
