I’m attempting to install the looking glass client from the AUR, this is the looking-glass
package, but the looking-glass-git
package also fails with a similar error. Anyone have any idea what could be causing this?
Full output:
:: Checking for conflicts...
:: Checking for inner conflicts...
[Aur:1] looking-glass-2:B4-1
1 looking-glass (Build Files Exist)
==> Packages to cleanBuild?
==> [N]one [A]ll [Ab]ort [I]nstalled [No]tInstalled or (1 2 3, 1-3, ^4)
==> A
:: Deleting (1/1): /home/user/.cache/yay/looking-glass
:: (1/1) Downloaded PKGBUILD: looking-glass
:: (1/1) Parsing SRCINFO: looking-glass
==> PKGBUILDs to edit?
==> Making package: looking-glass 2:B4-1 (Sat 27 Nov 2021 07:43:59 PM MST)
==> Retrieving sources...
-> Downloading looking-glass-B4.tar.gz...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 517k 100 517k 0 0 331k 0 0:00:01 0:00:01 --:--:-- 331k
==> Validating source files with sha512sums...
looking-glass-B4.tar.gz ... Passed
==> Making package: looking-glass 2:B4-1 (Sat 27 Nov 2021 07:44:03 PM MST)
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
-> Found looking-glass-B4.tar.gz
==> Removing existing $srcdir/ directory...
==> Extracting sources...
-> Extracting looking-glass-B4.tar.gz with bsdtar
==> Sources are ready.
==> Making package: looking-glass 2:B4-1 (Sat 27 Nov 2021 07:44:07 PM MST)
==> WARNING: Using existing $srcdir/ tree
==> Starting build()...
~/.cache/yay/looking-glass/src/looking-glass-B4/client ~/.cache/yay/looking-glass/src/looking-glass-B4
-- The C compiler identification is Clang 13.0.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/clang - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Performing Test COMPILER_SUPPORTS_MARCH_NATIVE
-- Performing Test COMPILER_SUPPORTS_MARCH_NATIVE - Success
-- GMP libs: /usr/lib/libgmp.so /usr/lib/libgmpxx.so
-- Found GMP: /usr/include
-- BFD libs: /usr/lib/libbfd.so
-- Found BFD: /usr/lib/libbfd.so
-- Found PkgConfig: /usr/bin/pkgconf (found version "1.8.0")
-- Checking for modules 'spice-protocol;nettle;hogweed'
-- Found spice-protocol, version 0.14.3
-- Found nettle, version 3.7.3
-- Found hogweed, version 3.7.3
-- Checking for module 'wayland-client'
-- Found wayland-client, version 1.19.0
-- Checking for module 'wayland-protocols>=1.15'
-- Found wayland-protocols, version 1.24
-- Checking for modules 'x11;xi;xfixes;xscrnsaver;xinerama'
-- Found x11, version 1.7.2
-- Found xi, version 1.8
-- Found xfixes, version 6.0.0
-- Found xscrnsaver, version 1.2.3
-- Found xinerama, version 1.1.4
-- Checking for modules 'egl;gl'
-- Found egl, version 1.5
-- Found gl, version 1.2
-- Checking for module 'wayland-egl'
-- Found wayland-egl, version 18.1.0
-- Checking for module 'gl'
-- Checking for modules 'freetype2;fontconfig'
-- Found freetype2, version 24.0.18
-- Found fontconfig, version 2.13.94
-- The following features have been enabled:
* ENABLE_OPENGL, Legacy OpenGL renderer.
* ENABLE_EGL, EGL renderer.
* ENABLE_BACKTRACE, Backtrace support.
* ENABLE_X11, X11 support.
* ENABLE_WAYLAND, Wayland support.
-- The following features have been disabled:
* ENABLE_ASAN, AddressSanitizer support.
* ENABLE_UBSAN, UndefinedBehaviorSanitizer support.
* ENABLE_SDL, SDL support.
* ENABLE_LIBDECOR, libdecor support.
-- Configuring done
-- Generating done
-- Build files have been written to: /home/user/.cache/yay/looking-glass/src/looking-glass-B4/client
[ 1%] Building C object common/src/platform/linux/CMakeFiles/lg_common_platform_code.dir/debug.c.o
[ 2%] Building C object common/src/platform/linux/CMakeFiles/lg_common_platform_code.dir/thread.c.o
[ 4%] Building C object PureSpice/CMakeFiles/purespice.dir/src/queue.c.o
[ 4%] Building C object LGMP/CMakeFiles/lgmp.dir/src/status.c.o
[ 4%] Building C object common/src/platform/linux/CMakeFiles/lg_common_platform_code.dir/event.c.o
[ 5%] Building C object LGMP/CMakeFiles/lgmp.dir/src/client.c.o
[ 7%] Building C object common/src/platform/linux/CMakeFiles/lg_common_platform_code.dir/crash.c.o
[ 7%] Building C object PureSpice/CMakeFiles/purespice.dir/src/spice.c.o
[ 7%] Building C object PureSpice/CMakeFiles/purespice.dir/src/rsa.c.o
[ 9%] Building C object LGMP/CMakeFiles/lgmp.dir/src/host.c.o
[ 10%] Building C object common/src/platform/linux/CMakeFiles/lg_common_platform_code.dir/time.c.o
[ 9%] Building C object common/src/platform/linux/CMakeFiles/lg_common_platform_code.dir/ivshmem.c.o
[ 11%] Building C object common/src/platform/linux/CMakeFiles/lg_common_platform_code.dir/sysinfo.c.o
[ 12%] Linking C static library liblgmp.a
[ 13%] Linking C static library liblg_common_platform_code.a
[ 13%] Built target lgmp
[ 13%] Built target lg_common_platform_code
[ 14%] Building C object common/CMakeFiles/lg_common.dir/src/stringutils.c.o
[ 16%] Building C object common/CMakeFiles/lg_common.dir/src/option.c.o
[ 16%] Building C object common/CMakeFiles/lg_common.dir/src/stringlist.c.o
[ 17%] Building C object common/CMakeFiles/lg_common.dir/src/framebuffer.c.o
[ 17%] Building C object common/CMakeFiles/lg_common.dir/src/countedbuffer.c.o
[ 18%] Building C object common/CMakeFiles/lg_common.dir/src/KVMFR.c.o
[ 19%] Building C object common/CMakeFiles/lg_common.dir/src/runningavg.c.o
[ 20%] Linking C static library libpurespice.a
[ 20%] Built target purespice
[ 21%] Linking C static library liblg_common.a
[ 21%] Built target lg_common
[ 22%] Generating ../../wayland/wayland-idle-inhibit-unstable-v1-client-protocol.h
[ 23%] Generating ../../wayland/wayland-xdg-shell-client-protocol.h
[ 24%] Generating ../../wayland/wayland-keyboard-shortcuts-inhibit-unstable-v1-client-protocol.c
[ 24%] Generating ../../wayland/wayland-pointer-constraints-unstable-v1-client-protocol.h
[ 25%] Generating ../../wayland/wayland-keyboard-shortcuts-inhibit-unstable-v1-client-protocol.h
[ 25%] Generating ../../wayland/wayland-pointer-constraints-unstable-v1-client-protocol.c
[ 27%] Generating ../../wayland/wayland-relative-pointer-unstable-v1-client-protocol.h
[ 27%] Generating ../../wayland/wayland-xdg-decoration-unstable-v1-client-protocol.c
[ 28%] Generating ../../wayland/wayland-idle-inhibit-unstable-v1-client-protocol.c
[ 29%] Generating ../../wayland/wayland-relative-pointer-unstable-v1-client-protocol.c
[ 30%] Generating ../../wayland/wayland-xdg-decoration-unstable-v1-client-protocol.h
[ 31%] Generating ../../wayland/wayland-xdg-shell-client-protocol.c
[ 32%] Building C object fonts/freetype/CMakeFiles/font_freetype.dir/src/freetype.c.o
[ 33%] Building C object displayservers/X11/CMakeFiles/displayserver_X11.dir/x11.c.o
[ 34%] Building C object displayservers/X11/CMakeFiles/displayserver_X11.dir/clipboard.c.o
[ 35%] Building C object displayservers/X11/CMakeFiles/displayserver_X11.dir/atoms.c.o
[ 36%] Building C object displayservers/Wayland/CMakeFiles/displayserver_Wayland.dir/output.c.o
[ 37%] Building C object displayservers/Wayland/CMakeFiles/displayserver_Wayland.dir/gl.c.o
[ 39%] Building C object displayservers/Wayland/CMakeFiles/displayserver_Wayland.dir/cursor.c.o
[ 39%] Building C object displayservers/Wayland/CMakeFiles/displayserver_Wayland.dir/poll.c.o
[ 40%] Building C object displayservers/Wayland/CMakeFiles/displayserver_Wayland.dir/clipboard.c.o
[ 40%] Building C object displayservers/Wayland/CMakeFiles/displayserver_Wayland.dir/idle.c.o
[ 41%] Building C object displayservers/Wayland/CMakeFiles/displayserver_Wayland.dir/wayland.c.o
[ 42%] Building C object displayservers/Wayland/CMakeFiles/displayserver_Wayland.dir/input.c.o
[ 43%] Building C object displayservers/Wayland/CMakeFiles/displayserver_Wayland.dir/registry.c.o
[ 44%] Building C object displayservers/Wayland/CMakeFiles/displayserver_Wayland.dir/state.c.o
[ 46%] Building C object displayservers/Wayland/CMakeFiles/displayserver_Wayland.dir/__/__/wayland/wayland-xdg-decoration-unstable-v1-client-protocol.c.o
[ 46%] Building C object displayservers/Wayland/CMakeFiles/displayserver_Wayland.dir/__/__/wayland/wayland-xdg-shell-client-protocol.c.o
[ 46%] Building C object displayservers/Wayland/CMakeFiles/displayserver_Wayland.dir/shell_xdg.c.o
[ 47%] Building C object displayservers/Wayland/CMakeFiles/displayserver_Wayland.dir/window.c.o
[ 48%] Building C object displayservers/Wayland/CMakeFiles/displayserver_Wayland.dir/__/__/wayland/wayland-relative-pointer-unstable-v1-client-protocol.c.o
[ 49%] Building C object displayservers/Wayland/CMakeFiles/displayserver_Wayland.dir/__/__/wayland/wayland-keyboard-shortcuts-inhibit-unstable-v1-client-protocol.c.o
[ 50%] Building C object displayservers/Wayland/CMakeFiles/displayserver_Wayland.dir/__/__/wayland/wayland-pointer-constraints-unstable-v1-client-protocol.c.o
[ 51%] Building C object displayservers/Wayland/CMakeFiles/displayserver_Wayland.dir/__/__/wayland/wayland-idle-inhibit-unstable-v1-client-protocol.c.o
[ 51%] Linking C static library libfont_freetype.a
[ 51%] Built target font_freetype
[ 52%] Building C object fonts/CMakeFiles/fonts.dir/__/src/fonts.c.o
[ 53%] Linking C static library libfonts.a
[ 53%] Linking C static library libdisplayserver_Wayland.a
[ 53%] Built target fonts
[ 54%] Creating object from shader/desktop.vert
[ 55%] Creating object from shader/alert.vert
[ 57%] Creating object from shader/alert.frag
[ 57%] Creating object from shader/cursor.vert
[ 58%] Creating object from shader/fps_bg.frag
[ 59%] Creating object from shader/desktop_rgb.frag
[ 60%] Creating object from shader/splash_logo.vert
[ 60%] Creating object from shader/alert_bg.frag
[ 61%] Creating object from shader/cursor_rgb.frag
[ 63%] Creating #defines from /home/user/.cache/yay/looking-glass/src/looking-glass-B4/client/renderers/EGL/shader/desktop_rgb.frag
[ 63%] Creating object from shader/cursor_mono.frag
[ 63%] Creating object from shader/fps.vert
[ 64%] Creating object from shader/help.frag
[ 65%] Creating object from shader/fps.frag
[ 66%] Creating object from shader/help_bg.frag
[ 67%] Creating object from shader/splash_bg.frag
[ 69%] Creating object from shader/splash_logo.frag
[ 69%] Creating object from shader/splash_bg.vert
[ 70%] Creating object from shader/help.vert
[ 71%] Building C object renderers/OpenGL/CMakeFiles/renderer_OpenGL.dir/opengl.c.o
ld.lldld.lldld.lldld.lldld.lldld.lldld.lld: : : : : : : error: error: error: error: target emulation unknown: -m or at least one .o file requirederror:
target emulation unknown: -m or at least one .o file requirederror: target emulation unknown: -m or at least one .o file required
ld.lld: error: target emulation unknown: -m or at least one .o file required
[ 71%] Built target displayserver_Wayland
ld.lld: error: target emulation unknown: -m or at least one .o file requiredld.lld: error:
make[2]: *** [renderers/EGL/CMakeFiles/renderer_EGL.dir/build.make:74: renderers/EGL/shader/desktop.vert.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: *** [renderers/EGL/CMakeFiles/renderer_EGL.dir/build.make:194: renderers/EGL/shader/splash_bg.frag.o] Error 1
make[2]: *** [renderers/EGL/CMakeFiles/renderer_EGL.dir/build.make:202: renderers/EGL/shader/splash_logo.vert.o] Error 1
make[2]: *** [renderers/EGL/CMakeFiles/renderer_EGL.dir/build.make:170: renderers/EGL/shader/alert.frag.o] Error 1
make[2]: *** [renderers/EGL/CMakeFiles/renderer_EGL.dir/build.make:130: renderers/EGL/shader/fps_bg.frag.o] Error 1
make[2]: *** [renderers/EGL/CMakeFiles/renderer_EGL.dir/build.make:98: renderers/EGL/shader/cursor_rgb.frag.o] Error 1
make[2]: *** [renderers/EGL/CMakeFiles/renderer_EGL.dir/build.make:178: renderers/EGL/shader/alert_bg.frag.o] Error 1
make[2]: *** [renderers/EGL/CMakeFiles/renderer_EGL.dir/build.make:162: renderers/EGL/shader/alert.vert.o] Error 1
make[2]: *** [renderers/EGL/CMakeFiles/renderer_EGL.dir/build.make:154: renderers/EGL/shader/help_bg.frag.o] Error 1
make[2]: *** [renderers/EGL/CMakeFiles/renderer_EGL.dir/build.make:90: renderers/EGL/shader/cursor.vert.o] Error 1
make[2]: *** [renderers/EGL/CMakeFiles/renderer_EGL.dir/build.make:114: renderers/EGL/shader/fps.vert.o] Error 1
make[2]: *** [renderers/EGL/CMakeFiles/renderer_EGL.dir/build.make:82: renderers/EGL/shader/desktop_rgb.frag.o] Error 1
make[2]: *** [renderers/EGL/CMakeFiles/renderer_EGL.dir/build.make:146: renderers/EGL/shader/help.frag.o] Error 1
make[2]: *** [renderers/EGL/CMakeFiles/renderer_EGL.dir/build.make:138: renderers/EGL/shader/help.vert.o] Error 1
make[2]: *** [renderers/EGL/CMakeFiles/renderer_EGL.dir/build.make:122: renderers/EGL/shader/fps.frag.o] Error 1
make[2]: *** [renderers/EGL/CMakeFiles/renderer_EGL.dir/build.make:106: renderers/EGL/shader/cursor_mono.frag.o] Error 1
make[2]: *** [renderers/EGL/CMakeFiles/renderer_EGL.dir/build.make:186: renderers/EGL/shader/splash_bg.vert.o] Error 1
make[2]: *** [renderers/EGL/CMakeFiles/renderer_EGL.dir/build.make:210: renderers/EGL/shader/splash_logo.frag.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:560: renderers/EGL/CMakeFiles/renderer_EGL.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 72%] Linking C static library libdisplayserver_X11.a
[ 72%] Built target displayserver_X11
[ 73%] Linking C static library librenderer_OpenGL.a
[ 73%] Built target renderer_OpenGL
make: *** [Makefile:136: all] Error 2
==> ERROR: A failure occurred in build().
Aborting...
-> error making: looking-glass
