Hey everyone, long time lurker first time poster! I come to you today in the hopes one of you have encountered a similar issue and got a working solution!
I bought an Elgato HD60 USB capture card a few months ago, and other then a few minor issues here and there it has been great. I've been using their game capture software for sometime and only in the past few days have I run into this weird audio crackling/popping issue. Short video https://youtu.be/ifHTDKQKzk0
My capture setup currently is an HD 7970 with an adapter to change display port to hdmi, leading to my elgato with another HDMI cord to my 1080p LG display. An aux cord to my front panel header from elgato. And the USB mini b from my elgato to mobo. I duplicate the sound using their sound capture software to play through both my speakers and the aux out! (A few weeks back I had this solution working with listening to the stereo mix in control panel/sound somehow, but randomly 1 day it just no longer worked and spent hours trying to fix and couldn't, so I settled for the elgato sound capture solution instead. It worked fine until this crackling issues started days ago.)
The crackling does not happen through my speakers at all, only in my game recordings! I haven' updated any software or done anything differently recently, but now no matter what I do it persists.
Things I Have Tried!
Switching all cables connected to Elgato , both HDMI cables, USB mini b 2.0 cables and the aux cord carrying my audio. My HD 7970 doesnt have hdmi so Im using a display port --> HDMI adapter
Disabling all unnecessary devices in control panel/sound
Disabling all enhancements from active devices in control panel/sound
Swapping my aux cord from my front panel HP jack to my Yeti HP jack
Plugging a different aux cord into my mobo directly to the Elgato HD60
Using different recording software (OBS)
Problem does not seem to happen while streaming (only recording)
Some solutions talked about webcam overlays and needing to drop the resolution. I don't have one but disabled the webcam overlay options anyways.
Some solutions said it could be CPU maxing out, but even under 60-80% load it still happens.
I'm almost exhausted out of ideas minus a clean install of windows (which is my absolute last resort.) The crackling seems random and I've tried to correlate it with key presses or mouse click , but it is not consistent. Sometimes it happens a lot, sometimes a little. Any ideas would be greatly appreciated and if we can discover a solution I'd be happy to post it all over the interwebs!
