Apologies for not using a paste site, however this build is SO big I had to leave it running overnight. I’ll use the code tag here and drop the file on a sharing site if anyone doesn’t want to use the code display here.
So ATM I’m trying to get some basic tools on OSX for porting some stuff. For starts, I wanted to port RetroArch as a test of the hardware, on top of packaging 1.7.8 for ppc, which isn’t available on the site. But, it still builds for the most part, I just need gcc48. To have gcc48, I need libgcc6 and 7. I’m not quite sure what failed, but there are a lot of missing flags. I’m not completely sure how to make those flags available, and on my other G5, either from void or ubuntu mate, I’ll build there and see if its just architecture limitations, but I don’t think thats the case.
Actually it turns out the log itself is 12mb big and keeps crashing my G5 browsers so I’ll just post the file on a file sharing site.
notice:configure ---> Configuring libgcc7
:debug:configure Preferred compilers: gcc-4.2 apple-gcc-4.2 gcc-4.0 macports-gcc-6 macports-gcc-7
:debug:configure Using compiler 'Xcode GCC 4.2'
:debug:configure Executing proc-pre-org.macports.configure-configure-0
:error:configure libgcc7 cannot be built while libunwind-headers is active.
:error:configure Please forcibly deactivate libunwind-headers, e.g. by running:
:error:configure sudo port -f deactivate libunwind-headers
:error:configure Then try again. You can reactivate libunwind-headers again later.
:error:configure Failed to configure libgcc7: libunwind-headers is active
:debug:configure Error code: NONE
:debug:configure Backtrace: libunwind-headers is active
:debug:configure while executing
:debug:configure "$pre $targetname"
:error:configure See /opt/local/var/macports/logs/_opt_local_var_macports_sources_rsync.macports.org_macports_release_tarballs_ports_lang_gcc7/libgcc7/main.log for details.
No real time stamps so don’t know if you actually worked around this but…
I have apple 42 installed. I’m letting ports do its thing pretty much. I’ll have time in the morning to really investigate this. I think its defaulting to what was installed first, so I’ll dig into this more tomorrow and see what my outcomes are.
I think the G4 entry might be a typo, but look at that shit! A G5 can do 5 and a half times more performance than other machines this guy has tested with.
