Hi,
after I played around with the ASUS Pro WS X570-Ace (BIOS 1302) in Windows I wanted to try ESXi 6.7 U3 with it (its intended final destination), but it cannot even boot since it crashes with a PSOD:
System configuration:
- 3700X
- 4 x 16 GiB ECC UDIMM DDR4-2400 (Samsung OEM)
- Quadro P2000
- USB Thumb drive with ESXi 6.7 U3 setup
- Empty/Erased SATA SSD intended for ESXi
- Nothing else
- CSM disabled/UEFI boot-only
Any idea what’s causing this?
CMOS resetting the BIOS didn’t change a thing (made sure to enable virtualization support afterwards since for some reason the default setting is leaving it disabled)
Installing ESXi 6.7 U3 on a different system (ASRock Rack X470D4U) to the SATA SSD, updating it to the current version (ESXi-6.7.0-20191204001-standard (Build 15160138)) and then trying to boot it on the X570-Ace also didn’t change anything
As always, I’m very thankful for your help!
Regards,
aBavarian Normie-Pleb
