Hi everyone,
I recently built a WRX80 workstation and I’m running into a strange issue that I haven’t been able to isolate.
Problem:
After a normal shutdown, Suspend (S3) or Hibernate (S4)
the system will sometimes refuse to power on:
Case power button → no response
Motherboard power button → no response
BMC power-on command → fails (no response after 3 tries)
This happens randomly (not Always).
The only way to recover is:
Turn off the PSU
Wait for capacitors to discharge
Turn PSU back on
After that, the system boots normally.
Behavior once powered on:
System is completely stable
No crashes or instability
Passes long stress tests (AIDA64, OCCT)
No issues under load
However:
- On the first boot after PSU reset, the system sometimes power-cycles once or tow during POST but It always eventually completes POST successfully whit AA Q-Code
Diagnostics / current state:
BIOS and BMC firmware updated to latest available versions (as of 16/03/2026)
Q-Code: AA (normal)
No POST issues
All LEDs off except for the blinking green BMC LED
AC power loss behavior: Restore to last state
What I’ve already tested:
Replaced PSU → no change
Verified all cabling
Tested RAM → no errors
Question:
At this point I’m trying to understand where to focus:
Could this be CPU-related at all?
Or is this more likely:
motherboard power logic / standby rail (5VSB?)
BIOS/firmware edge case
something related to WRX80 platform quirks
Also:
- Any reliable way to test the CPU?
(Motherboard and CPU are out of warranty so no RMA for now)
Build Component;
Motherboard = ASUS Pro WS WRX80E-SAGE SE WIFI
CPU = AMD Ryzen Threadripper PRO 5975WX
GPU = RTX 3080Ti + RTX 5000
RAM = G.SKILL Trident Z RGB - 256 GB (Kit 8 x 32 GB) - DDR4 3200 UDIMM CL14
Cooler = Silverstone XE360PD
Power Supply = Silverstone SST-DA1650-G, 80Plus Gold, modular - 1650W
Storage = 8 x SAMSUNG 990 PRO M.2 2000 GB PCI Express 4.0 V-NAND MLC NVMe
NVMe HBA =
4 x ICY DOCK EXLink MB308A - NVMe PCIe 4.0 x16 to 2 port SlimSAS 8i (SFF-8654) + redriver
PCIe Data Cable =
8 x ICY DOCK MB406L-B - data cable SlimSAS SFF-8654 8i to 1 SlimSAS SFF-8654 8i, 50 cm
SAS/SATA Data Cable =
2 x SilverStone SST-CPS04 - data cable Mini SAS HD SFF8643 to SFF8643, 0.5M
M.2 Heatsink = M.2 SSD Aluminum Heatsink with Silicone Thermal Pad
Backplane =
- E1.S Backplane for optical drive bay, Hot Swap, x8 Bay E1.S + x8 E1.S → M.2 adapter
- 8 Bay NVMe/SAS/SATA 2.5 inch, optical drive bay backplane, hot-swappable
Fans =
PHANTEKS D30 PWM Regular Airflow D-RGB, 3 pcs, 120mm - Black (push)
PHANTEKS D30 PWM Reverse Airflow D-RGB, 3 pcs, 120mm - Black (Pull)
Case
Anidees AI Raider XL
Full Tower Tempered Glass XL-ATX/E-ATX/ATX ,
Supports 12 x 5.25” Drive Bays & 480/360 Radiator
