I just put together a machine with a ASUS Pro WS WRX80E-SAGE WIFI II motherboard, a Threadripper Pro 5955WX CPU and an NVIDIA A6000 GPU, but I’m getting a “Fatal Error” with the Q-code of 78 (“ACPI module initialization”) and I can’t get into the BIOS settings menu (I’ve tried two different keyboards but it doesn’t respond to pressing Del or F2 during startup). I don’t have an OS installed yet.
When I started it for the first time, it said “New CPU detected” and gave me a choice of changing the BIOS but I can’t remember what I chose. Now, on startup it shows me text indicating that it recognizes the CPU, the RAM, two M.2 storage drives, and also USB devices (“1 keyboard, 1 mouse, 2 hubs”). I am plugging a monitor directly into the NVIDIA A6000 and that seems to work, too.
I tried updating the BIOS with the “flash” button, which reads a file from a USB file, and that worked – the text on the monitor now shows the updated version.
So I seem to be pretty close to having a working machine, except for the fatal error and the fact that I can’t get into the BIOS settings.
Is the key to clear the CMOS?
An ASUS tech suggested that I clear the CMOS, and this motherboard has a “Clear CMOS” button on the I/O panel, but I’m not sure if it should be done with the machine on or off (I tried both but it didn’t seem to do anything). The battery isn’t shown in the manual, but a forum suggested that it was under the VRM cover.
Anyway I’ve run out of ideas and I’d be really grateful for any suggestions. Thanks.
