So my Asus k55n hinges were working a little too well because they put a bunch of stress on the screws that held my laptop to the hinges. The part on the inside where the socket to the screw that holds my hinge to the computer broke the plastic part I can get a picture.
If this can be fixed I would like to try that. If it can't how do I find the bottom part of the laptop?
Go for the eBay replacement parts, but just as a side note, I found it interesting that its the hinge / hinge assembly again thats breaking on an Asus. I know their higher end ultrabooks such as the ux303 have had problems with hinges that don't rotate properly and break within a couple months of daily use.
