Hello.
I have got this board second hand, it looks like everything works, but i notice in bios that ME firmware is in recovery mode. I have bios 6605 i tried downgrade to 6102, but bios will show message that the image is not correct so i tried 6603 and that work fine but no change. After any bios update EZflash or biosflashback i will always get QCode bd, board will hang for 1-2 min, after that there are 2 boot attempt and third is successful. I tried change PCH_MFG1 jumper to pins 2-3 (security overdrive) the ME current state will change state to operational. Did bios update again and than change PCH_MFG1 back to (Default) pin 1-2 and ME is again in recovery mode. DId anyone encounter anything similar? Is something wrong with mobo? Do i lose some functions in recovery mode or should i leave the jumper in security overdrive mode?
Board have Two jumpers
ME_RCVR1 (for recovery corrupted ME) but there is no explanation how that works. Position Default or Force ME recovery
Jumper PCH_MFG1 description is this jumper allow to update ME block, but this will work in defaul position or in security overdrive mode?
Thank you
