I bout Astros a40s with the mix amp about a month ago. I played on my xbox for about 2 weeks and they worked fine. im in the process of a move so I pulled them to listen to music and cant get any sound. all I have hooked up is the aux cable to the head phones/. do I have to have the mix amp?
You can't do that much wrong, just plug the green marked connector on the Y-splitter in the regular audio out port.. Then plug the cable with the mute button in the splitter.
