I just finished my first build and it powers on but the screen does not display anything (components below). I have the HDMI cable plugged into the motherboard HDMI socket. I am unsure if it is a BIOS problem - the sticker says I have version 3.6, while the support for the Renoir APU was implemented in version 3.2. I think that means I should be good on that front. Before figuring out I was shipped version 3.6, I tried to flash the BIOS with version 3.2. The BIOS light turned solid green after it was finished, indicating the update didn’t take. There is not displayed an error code on the motherboard, only 00. Anyone with experience with an APU and ASRock X570 Taichi that might have experienced similar problems?
Components:
ASRock X570 Taichi
Ryzen 7 Pro 4750G
2x G.Skill 16GB 3600
Seasonic Prime Titanium 650W
4x 6TB EXOS
1x MP510 240GB
