Hi,
I’m upgrading my Unraid server and having trouble getting the Motherboard (Asrock rack E3C246D4U) to post with a Quadro P2000 installed. It runs fine without it. I also have an LSI 9207-8i installed. I thought maybe since the x16 changes to x8 when PCIE 4 is occupied might cause the issue but removing the LSI card didnt make a difference. With jsut the LSI card it runs fine. Is there a bios setting or jumper setting i’m missing?
the motherboard is running the latest bios version.
its the only one i currently have to test with. i’ll have to see if i can borrow one from work. i’m using a 750 watt PSU so it should be enough unless its something wrong with the board itself.
THansk for the replies. Once it stops booting i lose all keyboard controls. I tried using the card and onboard vga with similar results. Someone from Asrock had me try changing the Video OpROM policy to UEFI but that didnt work. I got a little further than before. It began to post but froze at the screen that shows the boot options. THe dr debug code it stopped on was 62. I have a processor that supports Quick Sync on the way so the card really wont be needed once i have that installed. My main concern now is do i have a board with a bad PCIe slot. i’m going to bring a different video card home today and see if it boots with that one.
