Hi
I am going to build a system with the ASRock DeskMini 110. I have a monitor with 4 holes in the back. They are 10cm away from each other. So, I suppose it's a VESA mount. Can I attach the DeskMini to my monitor?
Florian
Hi
Florian
You should look at Asrock website to see wich VESA standard is supported by the Deskmini mount.
I looked into the manual. There it says that it is mountable on 100x100 VESA mounts. But I don't know if the VESA mounting plate is included...
