Hi,
I am attempting to upgrade my home lab servers CPU and ran into an issue and I’m looking for help debugging.
Parts list:
- Asrock B550M Pro4
- 3400GE trying to migrate to 5750G
- 64 GB of ECC ram (KSM26ED8/32ME from the QVL)
When I use the 3400GE the server boots and operates perfectly. I swapped in a used 5750G and the machine won’t boot, the POST lights for CPU and DRAM are on. I then removed every connected component leaving only the CPU and RAM. The same POST lights are on. I tried swapping ram positions, using a single stick, using no sticks, nothing.
The seller of the CPU is offering to help debug and replace but I wanted to ensure I checked everything as waiting for another CPU from China will take some time.
The CPU is on the QVL, same with the RAM. I used the validated BIOS for the 5750G (1.80) and it didn’t change anything. I then tried the latest BIOS, same thing.
What else can I test? Is it possible the RAM isn’t compatible with the CPU change?
Dead CPU? It was listed as unlocked, could this happen if the CPU was indeed locked?
Thanks!
