Asrock 970 Extreme4 support for FX8320
Ok, so i am going to be building a pc soon, and I'm trying to work out parts, and I'm having trouble working out the compatibility of the Asrock 970 extreme4 with an FX8320.
On Asrocks website, it says they support it after update 1.40 http://www.asrock.com/mb/AMD/970%20Extreme4/?cat=CPU
but if it doesnt come pre updated then that means it wont support my cpu, and you need the cpu to boot into bios to update.. So can anyone tell me if the board will support my cpu, or suggest a board for the same price point (110 bux) that will?
thankyou
ok wait no. it doesnt support the 8320. can someone tell me a decent motherboard that supports the 8320 for about 100 bux?
asus m5a97a (not the le version)
I found an Asus m5a97-r2 from the store I'm getting it from. is that alright? And thanks :)
ah, thought it had an a at the end, same board, r2 just means the bios update has already been applied
what store are you getting it from? i went to microcenter planning to get that or a 970-ud3 but got a great deal on an open box asus 990fx board, i think it came out to 90 or 100 instead of 150
umart
http://www.umart.com.au/newindex2.phtml?bid=2
$118 from them excluding postage
  1. Asus M5A97 evo R2.0     6+2 powerphase digi vrm
  2. Asus M5A99X evo R2.0   6+2 powerphase digi vrm
grtz Angel ☺
