Just want to know if the ASRock 960gm/U3S3 mobo is compatible with the AMD 8350 as I am waiting for the Asus Sabretooth Gen3 r2.0 to be released.
It's not on the supported CPU list, but I don't see why it wouldn't. It does support 125w Phenom II's and the 95w FX-8300 is supported, but you need BIOS ver. P.120
It will likely work, but it might work at a reduced clock speed due to power constraints.
