I see that there are clearly external enclosures for Storage and GPUs that utilize USB 3.1.
I need an external enclosure for USB 3.1 that will support any normal PCI-e card I put into it.
Clearly the concept exists, but I can’t seem to find what I need. This is for a WiFi card.
Does such a thing exist?
They actually use Thunderbolt, not USB 3.1 Gen 2. If you try to plug in Thunderbolt into USB 3.1 Gen 2 USB-C, you get nothing. It has to be Thunderbolt, which is still pretty much Intel exclusive.
You’re looking for a Netstor. There’s one that supports this for a single slot card:
https://www.bhphotovideo.com/c/product/846531-REG/Dynapower_USA_NA221A_DT_1_SLOT_PCIe_EXPANSION_ENC_PCIe.html
So what does the enclosure plug into? I see it uses a PCI-e Host Card. Where would I plug that into a PC?
The whole point of this is to expand the number of slots available for a PC. Meaning that if I have to install a PCI-e card to plug this box into, I’ve gained no PCI-e slots.
The use case is an ITX system with a gaming GPU and a WiFi card. I need both.
You could look into a M.2 Wifi card. How old is the motherboard? If it has no M.2 slot then you may have to resort to a USB based Wifi.
That doesn’t really help me use this:
YIKES. Yeah, same M.2 idea, but you need a M.2 to x4 slot.
That… actually could work. Awesome, thanks!
This is for an ITX build and the build would have a gaming GPU so trying to get all-in-one ya know.
Wendell has tried this before on a Blackmagic capture card and GPU together on a ITX board:
