Are Motherboard standoff's all the same size!?
I have an ATX sized case and motherboard and my case came without any motherboard standoffs, I need to order some and wondered is it one size fits all or not?! URGENT HELP NEEDED HERE!
Yes they're all the same size.  At least all the ones I've seen are
how do I know which ones to buy?
What case do you have? My case didn't have standoff screws because they were built into the case excpet for two removable ones.
Also to answer your question yes. But check your case manual as well.
as long as all the ones you use are the same, should be ok.
it's a sharkoon T28 but it didn't come with a manual eithier some what ever you guys say here I'll taje litterally
yes they're the same size
