Are M.2 Socket (Key E) on motherboard compatible with A+E 2.5GB NICs?
I’m considering using a cheat code to get 2.5GB NIC out of my Asrock B660M Pro RS motherboard which has a M.2 Key-E for WIFI but I don’t know if I were to buy a “A+E” nic that it would work on that port?
This is the item: M.2 A+e 2.5g Ethernet Adapter 2.5g/1g/100m Multi-gigabit M.2 Network Card 8125b Com - Network Cards - AliExpress
This is my motherboard: ASRock > B660M Pro RS
Looking at the schematics for M.2 The M.2 interface it feels like a “Key E” has basically the same gap width of an “A+E” with just a few missing connectors. Does anyone know for sure?
Also I know the adapter above is Realtek RTL8125B - for a bit more money I can get the Intel I225 - worth it?
You might want to be a bit concered about signal integrity, a ribbon cable is probably not compliant in that regard.
You are likely right - I wonder if this is the same adapter @wendell shows in his videos? It may have been the ‘gigabit’ and not the 2.5g flavor of it. My board already has 1gb but looking to get 2.5g
Why not use one of the PCIe slots?
I have a PCIe 3.0 x1 slot left which would work but I was trying to exploit or use the pci lines that the “Key E” slot has to maximize IO rather than buy a PCIE 3.0 x1 2.5g nic
So yes, the key is correct so it will plug in here, and will work electrically.
It is always better to purchase an Intel Nic; (as long as you are getting a real Intel Nic) over a Realtek. There is better operating system support for Intel nic’s than Realtek. At least, this has been my experience. If you are purchasing your nic from Aliexpress, I would go ahead and buy the Realtek nic instead of the Intel one because what you most likely receive is a fake Intel nic.
thanks for the protip :slight_smile:
