Thanks! That was the photo I was after. Zipties it is then, if I ever receive the cooler. In the mean time I found used Noctua TR4 cooler, I guess that’ll work for now
Sharing the 3D Printable adapter I made to mount standard 120mm fans to the Arctic SP3 heatsink.
Just barely clears standard sized ECC RDIMMs but you can shift the mount up higher if you need to clear DIMMs with a heatsink.
More info/pics in the link:
Arctic Freezer 4U SP3 120mm fan adapter
Cool, thank you very much! This will be very usefull in case the original fans break.
Confirmed fit in Supermicro SC846 with Supermicro H12SSL-NT systemboard.
You will either need to remove the rear 80mm chassis fans or the rear heatsink fan to fit with this systemboard.
That’s lovely! Thanks for sharing
next I want to try a pair of phanteks t30
PH-F120T30 120mm, I think they might be perfrorming better than the noctua industrials.
I’d be interested to know whether your temperature improved with 3rd party fan or not. Of course, fair comparison at same noise level.
another good option is https://support.arctic.de
