Arctic p14 pwm fan clearance
Guys, am I doing it wrong?
Have you had similar problems with this model of fan?
I decided to replace front fans on my fractal define 7 XL. I have 12 HDDs in front and their temperature was a bit too high for my liking.
I’ve bought arctic p14 fan Wendell recommended a while ago.
Upper fan got caught and shuttered.
Middle fan was scratching metal of the case but I managed to fix that with cardboard spacers.
EDIT
Small update.
I eventually gave up, I’m way to busy and lazy to RMA 10 Euro computer fan.
Arctic insisted I send it to the seller. Seller didn’t want to refund it and claimed that really need that broken fan back. Eh.
fan build quality most likely, would contact artic, maybe these are out of spec. That shouldnt happen
I have 3 p14 fans. 2 faulty ones came from different seller than the first (good) one. Maybe it was a bad batch.
I’ll ask ask arctic support about this.
Keep us informed on how the interaction goes good to see how they good their customer service is
It’s the build quality (specifically the material) of the fan housing. The plastic is just too soft. Thermalright fans are like that too (except for their B series fans), hence the cheap price. Does not help that Arctic does not have great QC, so some batches are considerably worse than others. Basically, if you apply too much torque while screwing them in from the intake side, the housing will deform causing the impeller to swift out of place. Cases with front fan mounts like yours make the problem worse due to the metal tabs and rails for fan mounting. Either use spacers (2-5mm) or be extra careful when mounting them (apply the minimal torque necessary or use silicon fan mounts).
I’ve purchased another P14 fan from third seller.
This time I tried to be extra gentle while making last few turns with screwdriver. Fan works as expected without extra spacers.
Gently relaxing screws on one of the older fan didn’t help. I’ll still have. I guess it your bad batch/soft plastic theory is correct.
I’ve tried contacting Arctic support last week but they haven’t responded yet. I’ll try again this week
:frowning:
GL, if you do social media might be able to poke their support there as well.
