Arch. startx not starting KDE
I’m sure I did everything right. I installed KDE and when I run startx it gives me this error. If I install the missing stuff and run startx again instead of KDE it runs some minimal GUI, ruining everything and requiring me to reinstall the whole OS. Please help.
https://wiki.archlinux.org/index.php/KDE#Starting_Plasma
You have to modify .xinitrc file with the command to launch KDE using the startx command. You can also just use a display manager (SDDM is the standard one recommended for KDE Plasma).
Thank you. It worked.
NP! Installing Arch can be intimidating…
