I just bought an Arc Pro B50 (just waiting for it to arrive).
My Jellyfin/NAS server is currently using RTX 3060 Ti, and wanna setup vGPUs to have GPU-accelerated VMs in that server. Is it possible to bifurcate the GPU and have one of the vGPUs be used for Docker & LXD containers in bare-metal (i.e. my Jellyfin), and the other vGPU for VMs?
Haven’t tested that particular setup, but assuming you have VT-x support, you should be able to run an Alpine VM (and assigning a VF to it) with docker/LXD and negligible overhead.
Keep in mind that you’ll likely need to perform a firmware update on the B50 to use the feature.
I’m currently using 2 vGPUs (VF’s) with my B50 on a Proxmox virtualization host.. One vGPU is being used by a LXC container not assigned to a VM, and the other assigned to a Windows 11 LTSC VM. The VM was a bit finicky and only worked with a specific driver, but it does work.
Nice that helps!
Curious to know: did you ever try running AI with one of the vGPUs? if so, how is it performing?
I’m pretty much torn between:
- Server
- Replacing my 3060 Ti with Arc B50 for the vRAM
- Replacing my 3060 Ti with Arc B50, bifurcate into 2 vGPUs
- Gaming PC
- Replacing the 4060 in my gaming PC (2nd GPU) with a B50
- Bifurcate it and run Linux and Windows VMs on the GPU
No AI yet but planning to eventually.
