APU with GPU
alright so I'm not to smart and I haven't found a solid answer
can you have a graphics card in a APU build and they both run fine together
or is it better to just get a regular processor with a graphics card ?
you can have an apu and a certain gpu running at the same time. It's called dual graphics.
The AMD A10, A8, and A6 series APUs can run dual graphics but not with any card (obviously). I recently did a low profile build with a 6800K and an MSI 6570. The performance far exceeded my expectations.
You could go the dual graphic route, but that limits your selection of cards. The A10-6800k, especially with an OC, is quite the competent quad core. It will preform well enough with most cards and shouldn't bottleneck in most situations.
Dual graphics is explained pretty well above.
The current richland a10 isn't worth running dual graphics though.  The new a10-7850k may be.
Looking at the benchmarks provided from AMD, it apparently nearly doubles the framerate with the R7 260X.
source? it would be strange to crossfire it with a 260x/7790 when the onboard is a 7750
Yeah, I've only heard rumors that it'll be crossfire-able with the HD 7750.
