Pobs
June 27, 2017, 12:24pm
#1
Hi Guys,
I'm having trouble configuring virtual hosts on apache2. What i essentially want to do is have 3 sites created in the same way /phpmyadmin is configured.
i want users to be able to go to go to ip address or domain to see the main page and they from there to be able to put /service1, /service2 or /service3 and go to those individual sites.
I've tried to use ServerAlias and Alias in the service1.conf file but it just simply doesn't work. If i configure those virtual hosts as subdoims it works sine but i want them configured just like /pypmyadmin is.
Any suggestions are welcome.
501st
June 27, 2017, 12:34pm
#2
your config files would be helpful.
Pobs
June 27, 2017, 1:47pm
#3
my bad
This is the config of the main inventory webpage (works fine) /etc/apache2/sites-available/inventory.conf
<VirtualHost *:80>
ServerAdmin [email protected]
ServerName 10.99.100.42
ServerAlias inventory.uk.domain.eu inventory.uk.domain.eu
DocumentRoot /var/www/inventory/public_html
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
<Directory /var/www/inventory/public_html>
Options Indexes FollowSymLinks MultiViews
AllowOverride None
Order allow,deny
allow from all
</Directory>
</VirtualHost>
Here is one of the sub-pages i want. It's actually instance of netbox, In this particular example its also using reverse http proxy
/etc/apache2/sites-available/netbox.conf
<VirtualHost *:80>
ProxyPreserveHost On
Alias /netbox /opt/netbox/netbox/static
# Needed to allow token-based API authentication
WSGIPassAuthorization on
<Directory /opt/netbox/netbox/static>
AllowOverride None
Require all granted
</Directory>
<Location /static>
ProxyPass !
</Location>
ProxyPass / http://127.0.0.1:8001/
ProxyPassReverse / http://127.0.0.1:8001/
</VirtualHost>
And here would be just normal virtual host: /etc/apache2/sites-available/test.conf
<VirtualHost *:80>
Alias /test/ /var/www/test/public_html
DocumentRoot /var/www/test/public_html
<Directory /var/www/test/public_html>
AllowOverride None
Require all granted
</Directory>
</VirtualHost>
After each change and different setting I've have disabled site, restarted service, enabled site and restarted service again.
