great in-depth review! But I do have one question: You said/wrote in the review that ECC is confirmed, but from the logs it sounds to me like itās not working properly? What I mean is the line where it said āECC disabled in the BIOS or no ECC capability, module will not loadā.
Did you do some further testing or what is up with that line in the log?
Wooo thanks for the review @wendell. Been looking forward to this one.
Just placed an order for my 32GB RAM Kit - 2x packs of Corsair Dominator Platinum Series 16GB (2 x 8GB) DDR4 DRAM 3200MHz (PC4-25600) C16 (CMD16GX4M2B3200C16)
@comfreak Good point, curious to hear about that too.
I recall you posted a video on increasing the timings to improve the infinity fabric for slower sticks, i.e. a 2400 MT/s kit could perform similar to 3200 MT/s. Would you recommend this approach given there arenāt much options for ECC RAM past 2400MT/s?
I havenāt experimented with it much. Unless the ecc has really right timings you could probably bump from 2400 to 2666 or 2666 to 2800 but thatās about it.
If seems to have some latencies of itās own for sure. So it kinda works fudging it a bit.
The ryzen memory controller situation is for sure a bit weird. each die gets its own dual channel controller. I guess. Vs ātrueā quad channel memory on the other platform.
It does scale really well with serverish workloads, though, vs the other approach
Thanks @bsodmike - does the ACS patch improve that any? I notice the USB controllers are all bundled in with other stuff and ideally I would like to pass through a separate GPU and USB controller to each VM (probably 3 running at same time).
Hi all - Iād like to confirm that the Corsair Dominator Platinum 16GB Kit (2x 8GB) at 3200MT/s v4.24 sticks work flawlessly on this mobo. I added 2x sticks for 32GB and it booted into XMP straight away.
Handle 0x0046, DMI type 17, 40 bytes
Memory Device
Array Handle: 0x002E
Error Information Handle: 0x0045
Total Width: 64 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM 1
Bank Locator: P0 CHANNEL D
Type: DDR4
Type Detail: Synchronous Unbuffered (Unregistered)
Speed: 3200 MT/s
Manufacturer: Unknown
Serial Number: 00000000
Asset Tag: Not Specified
Part Number: CMD16GX4M2B3200C16
Rank: 2
Configured Clock Speed: 3200 MT/s
However, the universe wants to rain on my parade so my Threadripper box is down with a PSU OCP loop issue, so Iām sorting that out now.
EDIT ā I spoke too soon.
Having set VCORE SOC to 1.125vdc, CPU Core voltage to 1.4vdc, both DDR4 Channel Voltages to 1.4vdc, Iām only able to get a stable 2933MT/s OC on the Corsair sticks. Guess the v4.24 kit are not B-die after all.
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM 1
Type: DDR4
Speed: 2933 MT/s
Rank: 2
Configured Clock Speed: 2933 MT/s
Seems the āflawlessā boot up at 3200MT/s was a fluke. I canāt get it to do it againā¦
@wendell Were you able to get Windows 10 installed?
I had to disable IOMMU in the UEFI to get the installer running.
Once I get to the ācustom installā option in the installer and I choose my target SSD (connected to mobo SATA header), Iām able to select it. When trying to create a new partition or attempt the installer, it complains saying that the hardware controller needs to be enabled in the BIOS.
AHCI is enabled in UEFI. Do you need to load any particular drivers at this point?
