Any solution to connecting a lot of fans at once?
Hello all,
I am proceeding with a build with a few radiators and might end up with a whole lot of fans. I remember seeing a simple board that allows some 12 fans to be connected into a single 12V Molex 4-pin connector. Unfortunately I can't find it and I would love not to mess around with those cables that daisy-chain fans together. Does anyone know of something similar?
Thanks in advance.
http://www.scythe-eu.com/en/products/pc-accessory/kaze-q-12-lueftersteuerung.html
Thanks, but do you know of anything that's not a front bay/PCI fan controller?
Not for 12 fans...
I can use multiple connectors. No need for 12 at once.
There are fan power distribution blocks:
http://www.xoxide.com/modmytoys-3pcb-5wayblock.html
Personally I would not connect the motherboard's fan header to this, but instead convert a PSU output to 3-pin and plug that in.
Whoa- this is exactly what I was looking for!
2 more questions since I found this: Is there any that has a molex in? Also, is there any risk of me connecting one too many fans to this board?
EDIT: I found one with Molex-in. This is the one http://www.amazon.com/gp/product/B007S3T4O0/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
