Any issues to watch for window 11 24h2
I have decided start taking upgrade some the my lab vm with windows 11 24h2. I am upgrading from 22h2 Lab is running amd 3950x 5800x and 5700x cpu. Or at least that is first
It’s windows 11 so generally yes! Copilot would be the biggest one. It’s ms forced install of there ai tool! As for anything else I’m not sure as I haven’t really touched windows in over a year.
I have heard that you can completely remove Internet Explorer and Microsoft Edge. That should, for now, keep Coppiolt and Recall off of your system. Microsoft will fix this workaround in the future.
That is a new one for me!
You can remove edge but internet explorer does more as well as being hooked into certain things needed. Best not to remove internet explorer.
I knew that removing Internet Explorer would break some of Windows’s functionality. Right now, I am experimenting with a long-term evaluation version of Windows Server 2022 to see what I can remove while still making Windows useful.
Go over to the Ntlite forums, they have a wealth of knowledge on what works and what doesn’t when removing stuff. Also if you have any questions and don’t feel like seeing that forum;you can ask me
