Hello Everyone,
I'm currently looking to upgrade the CPU in my system, here is a breakdown of my parts:
http://pcpartpicker.com/user/MCV430/saved/22Pp
I currently run with a Sapphire HD 6950 2GB and was looking to upgrade to the MSI Gaming Twin Frozr for $259.00, which is right at my maximum budget or the Sapphire HD 7950 (100352-3L) for $241.00 after all applicable discounts from Newegg.com, which sits about $20 under the maximum I was looking to spend. I'm currently using one 1920-1080p display with no plans on using more. I also do not plan on using crossfire or SLI. I do however plan on overclocking, I'm still new to it but it is definately something I plan to do. One last thing, I do not have a preference for either Nvidia or AMD, I currently owned/ have owned a number of GPUs from both. I've seen after reading several reviews and benches that at stock the two cards trade off blows and are pretty much dead even overall. However I've heard that the HD 7950 is a far better overclocker, and once you've done so it'll far out perform the GTX 760. Can anyone give me some sound advice on which would be the better overall buy?
