An odd problem
So i have openvpn setup so i can get into my local network as needed. i used to be a able to ssh into my main desktop from my phone if i needed to.
However i cant now (nor can i ping the machine) but i can ssh into every other machine on the network, and from there ssh into my main desktop.
IPtables INPUT chain is empty, all other chains have to do with docker.
Edge firewall (pfsense) doesnt appear to show anything that would block my desktops ip either.
Open vpn is on a 10.10.0.0/24 network and my localnet is 192.168.0.0/24 if that helps.
I’ve had weird problems between some devices going between my old netgear access point and my wired network. In my case, the problem was a failing AP not forwarding some traffic correctly. I solved the problem by replacing it.
