Oh great and powerful Level1Tech Forum members,
I come to you in a time of great crisis. Last week, I created a RAID-6 array of eight hard drives. This is only the second time I have done this, and the last time worked without a hitch.
I updated and restarted my server, after migrating my home server to an updated rig. Now, it seems to have not mounted. My restart was placed into emergency mode because it couldn’t find the UUID I had assigned to my array. I tried to place the UUID I found in my /etc/mdadm into /etc/fstab but it didn’t work.
This is the /etc/mdadm/mdadm.conf:
# mdadm.conf
# !NB! Run update-initramfs -u after updating this file.
# !NB! This will ensure that initramfs has an uptodate copy.
# Please refer to mdadm.conf(5) for information about this file.
# by default (built-in), scan all partitions (/proc/partitions) and all
# containers for MD superblocks. alternatively, specify devices to scan, using
# wildcards if desired.
#DEVICE partitions containers
# automatically tag new arrays as belonging to the local system
HOMEHOST <system>
# instruct the monitoring daemon where to send mail alerts
MAILADDR root
# definitions of existing MD arrays
# This configuration was auto-generated on Wed, 13 Oct 2021 13:43:42 +0000 by mkconf
ARRAY /dev/md6 level=raid6 num-devices=8 metadata=1.2 name=hogwarts:6 UUID=5daeb81f:8bbaa6a4:79099875:fa470e1f
devices=/dev/sda,/dev/sdb,/dev/sdc,/dev/sdd,/dev/sde,/dev/sdf,/dev/sdg,/dev/sdh
This is blkid (all disks show as linux_raid_member):
/dev/nvme0n1p2: UUID="c5d6449b-813f-432f-9d6e-c23bd60bce41" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="94b0352d-3c62-47a8-b392-5e26cf6c76f2"
/dev/nvme0n1p3: UUID="9Noqi9-U14V-dwdC-Om3q-VLYV-ztSF-qIJxzF" TYPE="LVM2_member" PARTUUID="56069819-b335-4921-b837-a38037c4c654"
/dev/sda: UUID="5daeb81f-8bba-a6a4-7909-9875fa470e1f" UUID_SUB="dda28f07-9815-62ef-c344-94ccd122ff3b" LABEL="hogwarts:6" TYPE="linux_raid_member"
/dev/sdb: UUID="5daeb81f-8bba-a6a4-7909-9875fa470e1f" UUID_SUB="1b41413e-6586-8fc5-41f9-c91f41f20dd1" LABEL="hogwarts:6" TYPE="linux_raid_member"
/dev/sdd: UUID="5daeb81f-8bba-a6a4-7909-9875fa470e1f" UUID_SUB="9628cd73-810c-767f-7844-4862b9b146a4" LABEL="hogwarts:6" TYPE="linux_raid_member"
/dev/sdc: UUID="5daeb81f-8bba-a6a4-7909-9875fa470e1f" UUID_SUB="01e5432a-70c4-c221-5fee-b693b75fa8d5" LABEL="hogwarts:6" TYPE="linux_raid_member"
/dev/sde: UUID="5daeb81f-8bba-a6a4-7909-9875fa470e1f" UUID_SUB="cf625a8d-b6ab-8db6-8f49-9565d08f21c2" LABEL="hogwarts:6" TYPE="linux_raid_member"
/dev/sdf: UUID="5daeb81f-8bba-a6a4-7909-9875fa470e1f" UUID_SUB="dca5d8b0-f8ed-23fb-4a70-0152b0f631b1" LABEL="hogwarts:6" TYPE="linux_raid_member"
/dev/sdg: UUID="5daeb81f-8bba-a6a4-7909-9875fa470e1f" UUID_SUB="aea7053e-5163-735a-bda0-db4507b1b5e4" LABEL="hogwarts:6" TYPE="linux_raid_member"
/dev/mapper/ubuntu--vg-ubuntu--lv: UUID="21d93b85-ce5e-4eda-ab5c-65dac1f99003" BLOCK_SIZE="4096" TYPE="ext4"
/dev/loop0: TYPE="squashfs"
/dev/loop1: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
/dev/loop4: TYPE="squashfs"
/dev/loop5: TYPE="squashfs"
/dev/nvme0n1p1: PARTUUID="d079945d-c1a9-4673-b2bc-1cc5500b23d4"
And this is the /etc/fstab (last line is the added array)
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/ubuntu-vg/ubuntu-lv during curtin installation
/dev/disk/by-id/dm-uuid-LVM-p5z0h4H2ZzsuOoq1bZM20mfqmYSU7ds9s35C0WPkSv260TfKf0YPcX7JbvNxqH8j / ext4 defaults 0 1
# /boot was on /dev/nvme0n1p2 during curtin installation
/dev/disk/by-uuid/c5d6449b-813f-432f-9d6e-c23bd60bce41 /boot ext4 defaults 0 1
/swap.img none swap sw 0 0
UUID=21d93b85-ce5e-4eda-ab5c-65dac1f99003 /mnt/raid6 ext4 defaults 0 0
I am at a complete loss as to what to do, and have pretty limited knowledge about mdadm, I followed guides to set this up. (There is an empty directory at /mnt/raid6)… Thoughts?
