AMD Radeon VII Question
So in regards to the above listed GPU, is it going to be an issue with REBAR/SAM enabled in the BIOS when using this GPU ?
Mobo is the X670E chipset on an ASUS platform.
Also the GPU is limited to PCIe 3.0 so leaving the Primary PCIe slot at AUTO should allow the mobo to detect the proper speed and set this up accordingly, correct ?
At some point I will be replacing it with an a more updated GPU but have not seen a need just yet.
Any tips or advice on setting the proper BIOS settings ?
Maybe forcing both settings accordingly ?
