I have no idea which CPU to get I will be doing gaming on the PC and no rendering or anything like that, yet at least. But I saw on Tigerdirect that the 8350 is $179.99, so idk if I should get it. I don't think it makes that much of a difference as far as quality of the games does it?
8350 if it is cheaper than the 2500k/3570k.....
Depends entirely on your budget. If, to get an 8350, you have to compromise on somthing else important like your GPU, then don't buy it. It won't make a huge difference in games as of right now, but it will down the road as more games become optimized for 8 cores.
