My idle temps with my AMD FX 6300 is around 30 degrees celcius. Is this too high idle temps? I'm using a cooler master hyper 212 evo. I think i may have used a bit too much thermal paste, it was very close to the edges. Should i reapply the thermal paste?
No thats normall (if you have AMD amd cool and quiet disabled) 30-35c is normall ...also depends on the ambient room temps
It's fine, I've got the 4100 with a 212 evo in push pull an it's usually around 27 at idle so 30 is fine
temps look fine.
