I have seen that some people have had issues with getting cpu host-passthrough working for libvirt when using qemu 5 and a 5.6 kernel on AMD Ryzen CPUs.
Below I have a quick fix for this that allows you to use libvirt without using qemu:commandline.
Method :
- Apply the below patch to :
/usr/share/libvirt/cpu_map/x86_features.xml
@@ -480,6 +480,9 @@
<feature name='ibpb'>
<cpuid eax_in='0x80000008' ebx='0x00001000'/>
</feature>
+ <feature name='amd-stibp'>
+ <cpuid eax_in='0x80000008' ebx='0x00008000'/>
+ </feature>
<feature name='amd-ssbd'>
<cpuid eax_in='0x80000008' ebx='0x01000000'/>
</feature>
- Add a line to disable amd-stibp on your guest (something like)
<cpu mode='host-passthrough' check='none'>
<topology sockets='1' dies='1' cores='4' threads='2'/>
<feature policy='require' name='topoext'/>
<feature policy='disable' name='amd-stibp'/>
</cpu>
May need to restart libvirt services
Start your guest OS
I will probably submit a patch adding that cpu feature to libvirt later if one hasn’t been made already
