So the current build i was planning to get but its over my budget :( (http://au.pcpartpicker.com/p/7jjpWZ)
So if you guys could make a cheaper build for around 1.3k but with the 8350's and still keep the 970's or a card thats equivalent to its performance that would de dope.
Thanks :P
This is a bit cheaper.
http://au.pcpartpicker.com/p/rBPVZL
Didn't ditch the i5 though.
Dear god AU pricing is bullshit. Cheapest R9 290 is $380? Awful.
save youself some money get a 8350. It more than what you need but"""""""""""""""""
more than what you need but.??????????????????
aussie pricing just keep goin up :P
yo would it be better to have a 8350 and keep a 970 or nah
What do you plan to do with this computer?
The R9 290 is a very capable card, just under the 970.
I would go for it. ? pretty awesome set up. I havent tap my 8350 yet so for a more average ?
Personally I would drop to the 290 before dropping the i5, but that's just because I play some games that heavily favor the i5 such as Starcraft 2. To be honest, there isn't a huge performance difference between the 8350 and i5 as well as the 290 and 970 in most games, so it just comes down to what you play.
Personally, i like the idea of two 290's ? I understand the extra heat and such but that is alot of pixel pushing power.
http://au.pcpartpicker.com/p/6kfPhM or http://au.pcpartpicker.com/p/rBPVZL
kinda plan to use the comp for gaming, might do utube so vid editing and stuff so im probably better of with da 8350's right
For the average person . ya 8350 is very much good enough. But keep in mind your single core performance will not be the best.
