Wow, thanks guys! I decided to just add a 7970 and pay the little bit more! Can't wait until I get the money for this build! Lol Z Thanks again you guys :D
It can be cheaper if you choose the 2GB 670s, but obviously the 7970 would be the better choice as it is somewhat faster in a lot of cases( and gaming), and the 1GB edge over the 670 is only the icing on the top. So I chose to show the 4GB one, to show some competitiveness.
Either way, you can't go wrong
Also, LOL. I don't think I can fit a 7970 in any budget.
Can you please elaborate? I was actually looking at that exact mobo, and it was a bit over what I was planning on spending. I just really liked to looks of it. But if you have any solid reasons not to get it or other suggestions I'd definitely love to hear it haha.
the TA990FXE is the best performing motherboard when you do overclocking, while the UD5 and UD3 are a bit lower than all the rest but score nearly identically except when overclocking very high in which the UD5 does slightly better than the UD3
the issue with the TA990FXE though is that with multiple GPUs it dosent perform as well as the others, but still above the UD3
Eh, I don't really have the budget to spend 140$ on a motherboard. Like, the 125$ for the Gigabyte is a bit overkill, I just really wanted a 990 on the build. Thanks though!
Hey Guys here's the new build, I actually just got a EVGA 670 because that is all I need, and I might do some rendering/editing so the cuda core technology would help a lot!
