AM4 mATX motherboad with connectivity options
I currently have an ASUS TUF GAMING B550M-PLUS (WI-FI), with a 5800X. It has 3 PCIe slots, 1x, 16x (physically and speed), and 16x (physical, but 4x speed). As I understand from the manual, I can also configure both slots to be 8x. The 1x isn’t really usable without throttling the other two.
On the primary 16x slot I have an Intel Arc 750 running at 16x, and the 2nd 16x slot has an NVMe carrier board with 1 NVMe SSD running at 4x. All my regular NVMe slots are also occupied (1 PCIe 4.0, and 1 PCIe 3.0).
As you can see I’m maxed out. But I need a connectivity option, either high-speed networking to connect with my MS-S1 Max (maybe 100G, or 25G) or something like OCuLink so that I can attach an eGPU. I guess the easy answer is to get an ATX motherboard, but my case (Fractal Design Meshify C Mini) is only compatible with mATX or ITX.
I’m looking for options, but I’m also budget constrained, since I want to get an Intel Arc Pro B70. Any suggestions what I could do get some connectivity?
PS: I’m running Fedora as my OS.
The B550 mATX board you have is basically as good as it gets. The simplest solution is to install a NIC in the 3.0x x1 slot. PCIe 3.0 x1 is 8 gigabit worth of bandwidth. It’s not 25gig, but it’s still faster than gigabit.
Beyond that I’d think about switching to an ATX case where you’ll have more motherboard options, or consolidate from 3 NVMe drives to two and use the x4 slot for a NIC.
No you cannot. The fake x16 actual x4 slot is wired to the chipset and cannot be turned into a x8 by sharing lanes with the main x16 slot that is wired to cpu.
This is also wired to chipset, so its sharing the same pcie x4 connection between cpu and chipset as the fake x4. The main x16 is unaffected as it is wired to cpu
Thanks for the comment. I wish SSDs were even a bit cheaper :(. I got the third one few months ago, 2TB was the largest I could afford (about 70% above Sept 2025 prices). It’s a Lexar branded drive with YMTC flash chips. Ideally I would have liked a 4TB SSD to replace one of my other two SSDs, and get rid of the NVMe carrier board.
I guess I’ll look for an x1 network card. Thanks again :slight_smile:
Thanks for the correction.
That board does support Bifurcation on the top 16x slot. However the arc 750 isn’t going to like the other slots.
@ OP: If your limitation is money, not wanting to upgrade to a larger case and motherboard, then the B550m is the best you’re going to get. There isn’t a replacement that unlocks more, without going Gen1/2 Epyc or ThreadRipper (very rare now, and price prohibited).
To add onto this quote above, splitting the X16 slot into two x8 slots is the OP’s best way forward if they are determined to stick to AM4 in mATX form factor. However, this will require a significant investment - and a new open air chassis to dangle two GPUs in the air with riser cables.
An investment that switching to a full ATX chassis and motherboard is far cheaper.
Do note that true dual x8-to-the-CPU X570 full ATX motherboards are a very high premium price these days - for exactly that reason: dual GPUs at x8. E.g. the AsRock X570 Tachi for around $450 used on eBay (regular X570 that are only a single x16 can be had for around $90 as a comparison, new).
Local Ai has infected everything.
Thanks for your comments. Essentially I’m hesitant to switch to ATX partly because of cost, but also because of other logistical reasons (I live in rental accommodation in a foreign country, so would like to avoid accumulating large items). I think I’ll try the suggestion in the post marked as solution to consolidate my SSDs. That should allow me to drop the NVMe carrier board, and free up a x4 (x16 physical) slot.
I’m also considering dropping this idea, and instead try to just get an eGPU for my Minisforum MS-S1 Max.
