I was just browsing newegg and I came across this CPU. http://www.newegg.com/Product/Product.aspx?Item=N82E16819113348 Through further investigation, this CPU seems to be one of the best if not the best budget CPU under a $100. So I went ahead and put together this build on PC partpicker.com. Now note that Pcpartpicker.com doesn't have the AMD 760k cpu yet but has the 750k one instead. I will be using that as a place holder for the 760k since the are the same price.
The total price is $512. Same price as the Xbox One. I think this is the best kill your console build out there. If you can change up the parts and be in the same ball park, please tell me.
Now I personally wouldn't dare build this. I would save up for highier quality parts but for someone who is on a budget and wants the best pc for the same price as a xbox one than this is it.
Well, that is pretty damn good for the price, but I don't like that PSU. I would get a Seasonic G 360 for the same price, if not a Rosewill Capstone 450, both of which are higher qualiy units and closer to the actual power need of this rig.
It would hold back the GPU. However, you would get a higher framerate with a 7950, in comparison the a 7870. The 7950 is an appropriate price right now. 3 months ago, this design probably would have had a 7850/ 7870.
There was a test between the 750K and an i5, and the 750K actually held up pretty well. I'll find the video(s), if you wish to see it?
