hello eveyone justed wanted to know what you guys think of this gaming desktop is it worth the price, as i would like to play games like Battlefield 3 on ultra and achieve 50+ frames, thanks
according to pc part picker just the mobo, cpu, and gpu only need 263w to run so a 260 should run it easily. according to outervision extreme psu calculator the recommended wattage would be 315w but the minimum would be 262w
well im kinda waiting for him to reply if he wants a computer part list put together, and in my experience its hard to convince someone dead set on getting a computer prebuilt to build thier own. i also dont want to put together a part list and have it not looked at by him
Get the build that Eschippers suggested, although I'd change the mobo, SSD, and HDD to these
http://pcpartpicker.com/p/orhF
That would save you enough to get a 7950, which will give you 60 fps on Battlefield 3 at Ultra settings, or you could spend the extra 100$ if you'd like and get a 7970. And as for the other parts, the SSD is the same that Logan recommended, and is stupid fast.
